Results 1 to 18 of 18
    Oct 2015
    Mesa, AZ
    Default 2015 RT runs rough and trouble starting
    My 2015 RT has started running rough (idle RPM jumps between 800 and 900), and also doesn't start without cranking. I have to give it gas while starting. This is intermittent. Sometimes starts on first push of the starter. Other times, crank and crank and crank. Not dependent on warm or cold. I had it in to a shop. $840 later, no change. What does this sound like? Anyone have this happen?
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    Cracked vacuum hoses ?
    Happy Owner
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    Quote Originally Posted by bainvillewendy View Post
    $ 840.00 later ? For what? Seems to me that a 2015 should still be on Warrenty? Hope it gets figured out soon.
    Don't ever touch the throttle when you're trying to fire it up... you're just flooding it, and may actually be causing the problem.
    Otherwise... I'd bet that it's a batch of bad gas.
    Jul 2016
    Winder, GA
    What Jheck said. ?????
    Mark in GA
    2014 Cognac Spyder RT Limited - SOLD
    2014 Cognac RT-622 Trailer - SOLD
    2014 RT Limited , Stock Cognac
    Active Member kbwitt's Avatar
    Jun 2015
    AZ
    Default Sea foam
    I was having same problem, put some sea foam in cleared. Now if in an area were I do not feel they sell much high octane gas I buy the cheapest and put in an additive.
    Good luck kenn
    Oct 2015
    Mesa, AZ
    Warranty ran out three weeks before I brought Spyder in to the service dept. They changed plugs and put it back together. Nothing changed. I have been through several tanks of gas, so I don't think it is bad gas.
    If I don't turn the throttle while starting, all it does is crank. (sometimes it starts right up)
    I had a 2012 Spyder RT that had cracked vacuum hoses, but it had 20,000 miles on it. My 15 has only 13,000. Still new.
    Appreciate any other comments!
    Default Try this....
    Run some injector cleaner through with the next tankful. Also get to the throttle body and clean it as well. They may be blocked and only flow with high demand...
    ​2012 RS sm5
    Active Member 5legsshort's Avatar
    Mar 2015
    Kansas City North, MO
    Do you store it where the mice could have possibly built a nest in the air filer box or chewed through something important?
    Oct 2015
    Mesa, AZ
    Default No mice
    My Spyder is never stored. I ride it in Montana in the summer, and Arizona in the winter. (Lucky me!)
    Default EXCESSIVE CRANKING
    I have a 2014 RT w/1330 also ..... right from day one I have had issues with starting ...... I MUST keep it on a Maintainer.... IMO the dealer DIDN'T do the initial charge ... PROPERLY .... I have a 2011 RSS and never have an issue with starting it........ This may not be your issue - but it may ....annnnnnnnd I'd be concerned with a Stealer that charged $840.00 and didn't FIX THE PROBLEM !!!! ... good luck ..... Mike
    Jun 2010
    Las Vegas
    Quote Originally Posted by fastfraser View Post
    No vacuum hoses on the 1330s. Good idea though
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2010
    Las Vegas
    That's a good idea. I was having the rough running issue last year and injector cleaner did the trick.
    2010 RT- 622
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Sounds to me like the throttle by wire (TBW) could be bad. or some sort of throttle position sensor is goofy. could be sucking tween the throttle body and the intake also. spray some wd40 around the base of the throttle body while it's cranking and see if that helps.
    Dec 2008
    Connecticut
    Default 2008 Manual Shift Spyder 33,000 miles, Starts Rough
    starting to have an issue once its hot and shut off for say 15 minutes I have to turn the throttled and crank before it starts. Then runs rough for a couple minutes. I tried putting new OEM NGK plugs in, didn't change. Been through a couple tanks of gas so it not bad fuel. When cold or cooled down all the way its fine. Have Hindle and K&N air filter. Saw something about running some fuel injection, have not tried that yet. Anyone else having this issue ??
    Aug 2007
    Greeneville, TN
    $840.00 to change 3 spark plugs?!!!
    That is $280.00 per plug!!!
    And the icing on this cake is that it didn't fix anything....
    I agree with those who say you already paid for a fix. You should go back to the dealer and get what you paid for.
    Good Luck!
    Very Active Member ahh-cool's Avatar
    Jun 2014
    south florida
    I had a similar problem, changed the wires and that fixed it
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by ahh-cool View Post
    No wires on a 1330....
