Page 1 of 3 123 LastLast
Results 1 to 25 of 70
    May 2016
    Okotoks,Alberta, Canada
    Question Knock off or BRP hitch ?
    Just picked up a new Freedom Trailer !! $2300 ... now should I get a BRP Hitch n wiring or a knock off ? Give me ur thoughts please !!
    Default Choices, choices
    There are now quite a few out there and all seem to work well. I think canamspyderaccesories.com/SpyderTVcom has a great deal on hitches with the wiring. Tell Pierre Gene sent you....it is a choice but the price would be the main thing...
    ​2012 RS sm5
    on the new addition!
    Do yourself a favor, and get the hitch that was designed for the bike: BRP's!
    Ir's a little bit more money, but a whole lot more hitch.
    of the trailer?
    Idaho
    Quote Originally Posted by Blackie312001 View Post
    There are almost as many threads here about hitches as oil and tires. Put hitch in the search box and read until your brain goes fuzzy!
    2014 Copper RTS
    I don't know if it's a big issue for you or not...
    Bolting on the BRP hitch will maintain your vehicle's warranty.
    (I don't know if that's a thinly-veiled threat or not... but it's worth considering!)
    Active Member The Bee!!'s Avatar
    May 2014
    Eureka, MT
    I too am wonder about the best hitch and wiring for a hitch. I have Bushtec trailer, from what i understand is that the BRP hitch doesn't do well with the different bushtec hitch. And what about the wiring? I also read that BPR wiring doesn't like the set up for bushtec? So looking for recommendations? And what is the difference between a hitch that goes through the axle or attaches to the frame?
    Thanks
    Teri
    2014 RT-S
    YELLOW
    BajaRon Anti Sway bar
    Adjustable handle bars
    SpyderPops Skid plate
    Default BUSHTEC HITCH
    Quote Originally Posted by The Bee!! View Post
    Thanks
    Teri
    IMHO ....The Bustec design is the best one out there, it is basically a stiff hitch that doesn't allow any slack between the Hitch and the trailer Tongue...... So there is never any snapping back and forth .... this is what causes excessive stress on all the drivetrain components..... In fact the last I heard Honda will VOID your warranty if you attach a Hitch to the drivetrain ...... I have made tow assemblies that use a " TIE-ROD " end from a trk steering rack for all my liteweight trailers ...... Mike
    May 2014
    Eureka, MT
    So, do i get the BRP hitch with the wiring and then get an adapter for the trailer?
    2014 RT-S
    YELLOW
    Mar 2013
    Maumelle, AR
    I say go with the BRP hitch.
    2020 RT Limited , Chalk
    Idaho
    http://www.spyderlovers.com/forums/s...=1#post1230333
    2014 Copper RTS
    Sep 2007
    Rome, WI and Mayfield, KY
    I had the opportunity to see the show chrome hitch and the BRP hitch installed on 2 bikes sitting next to each other. I just liked the looks and substantial feel of the BRP hitch. I found one used on eBay and then went with the Show chrome wiring harness. While it could be a production issue or excessive wear, the installed show chrome hitch was showing some of those small rust spots at the welds. I'm sure there is no impact on its use but just didn't look as nice.
    Lucky
    2015 RTS SE6
    2008 Harley Ultra
    1999 BMW R1200C
    1986 Harley Electraglide
    But if you have a drivetrain problem?
    BRP will make you sweat...
    How about an electrical problem from some improvised wiring?
    Same thing!
    How much is your "Peace of Mind" worth?
    May 2016
    Quote Originally Posted by Copperman View Post
    Would I need to take the back wheel off to install the BRO hitch ?
    No. The hitch installation is done "through the existing bolt".
    Jun 2010
    Las Vegas
    No, the hitch has its own axle that goes through the Spyder axle. The BRP hitch goes on and off very easily. Sometimes you may have to coax it off with a rubber mallet but even that is easy.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Idaho
    Same thing!
    If BRP can show the improvised wiring caused the failure, you are probably SOL. Same if they can show that a Show Chrome harness, hitch or otherwise, caused the failure.
    2014 Copper RTS
    Default WARRANTIES AND BRP
    So now that we have heard from the DOOM & GLOOM crowd ..... if anyone has made any purchases from any VENDOR other than BRP ..... according to the aforementioned folks ..... you all need to be shaking in your boots , that your WARRANTY is practically WORTHLESS ...... Boy that bunch has sure made me feel GREAT .... What's really interesting is the Doom & Gloom crowd very often recommends things from the LaMonster garage ...........sort of hypocritical to me ......... Lamont just keep doing what you are doing, I have no BS warranty fears ....................... rant over ....... Mike
    Nov 2013
    Oro Valley Arizona
    Do yourself a large favor here and buy the BRP Hitch and wiring Harness. You will have far less headaches in the long run. Nothing quite like buying OEM. This site is filled with hitch and wiring problems from people trying after market cheap parts. Then when they install or use it they are asking everyone for help because it does not work properly or in several cases the hitch actually broke.
    You get what you pay for. In most cases to get the after market parts to work properly you wind up spending the same as OEM parts plus the grief, frustration and possible divorce!
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    May 2016
    Quote Originally Posted by SpyderAnn01 View Post
    Ok .. Now after I purchase the BRP hitch and wiring harness ... I can install the hitch myself .. But what about the wiring module? Has anymore here installed it ? Is it difficult ? Is there a
    how to link ?
    Yours thoughts again please ....
    Default OEM-PARTS
    Quote Originally Posted by jaherbst View Post
    ​Jack
    ........... So Jack is Super Clamp .....OEM ????? ....you seem to love that .... Mike
    Registered Users Mr. Pickels's Avatar
    Feb 2017
    North West Arkansas
    Default I concur ....
    of the trailer?
    Registered Users justcalldon's Avatar
    Apr 2015
    Caledonia
    I like my BRP hitch, it looks good and the extra splash guard helps too.
    If I'm part of the "Doom & Gloom" club: I nominate Jack for President!
    Seriously: As an insurance guy, I spend all day thinking about what can go wrong, and how to avoid it. Will a hitch cause a catastrophic component failure on your Spyder? Probably not!
    But if something DID happen: wouldn't you want it's resolution to be as trouble-free as possible?
    For the record: As of now, I don't have a trailer or hitch. I keep looking and shopping, hoping to find the right combination for when I eventually will need one. That's how I do things: I consider all of the apparent choices carefully, and mull them over in my little pea-brain!
    May 2016
    Default BRP Trailer wiring
    how to link ?
    Thx
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    I do not wear BRP underware. I did my own wiring with relay isolation unit with battery power. And on the hitch they all work. Do not exceed the BRP recommend pull weight! Now at 32 k miles and no problems. Never use a clamp-on wiring! Go plug and play or do your own with solder connections done correctly.
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
