Down Shifting ?
2nd Question of mine
I have the pedal shifters if eco mode is off does it automatically down shift or do I have to?
DOWN - SHIFTING
When you said " pedal " ... I assume you meant " PADDLE " as in SE - trans ........... if so, this trans is designed to downshift automatically in any MODE ..... Just for info purposes the APRILLA - which uses the Rotax engine & transmission has it's computer programmed to be FULLY AUTO with the ability to go fully MANUAL ......and with the same trans we use ..... It's done in the computer ...... at least this is my understanding of it ...... Mike
Yes sorry dam spell check
MIKE
BRP NEED TO FOLLOW SUIT WITH APRILLA
HP TOO
Agreed, I rarely feel the need to downshift manually.
The main time would be to initiate an overtake when I want to be in a lower gear for more performance.
That's proabably my only crticism of the SE6 transmission - no 'kickdown' as you get in auto vehicles. Would be nice if it detected a sudden twist to full throttle and went down a couple of gears by itself to get into the powerband.
| 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
Personally I always down shift my self, except from 2nd to first at a stop. I prefer to be in control and there are many times going through corners that the computer and I may not be in sync, so I take the decision away from the computer.
