Bumpskid problem
Hi all,
has as anyone else had issues with their LED bumpskid? Mine worked good for a while than started having burnout... Spyderpops was great about replacing the strip and sent me a replacement. It took me a while to get around to replacing it but when I did the covering on the strip did not cure and came off as I tried to install. Again, Spyderpops was great and sent a replacement. I installed it today and when I turned the key to check out my work, it be damned if it didn't had 2 o3 burnouts....
anyone else having this issue.. should I just cut the wire and be done with it?
mark
Bullies are sad pathetic People
I have had the bumpskid with LED's on my F3-S for over a year now. The only issue I ever had actually had nothing to do with the bumbskid or the LED's. I hit a large stick that was in the road and it cut the LED strip. I called Spyderpops and they sent a replacement LED strip right away. Install was a breeze and it has been working flawless ever since.
2015 Spyder F3-S
