Results 1 to 10 of 10
Thread: Wanna be
    Feb 2017
    Out West
    Default Wanna be
    I'm looking to purchase a used spider but I have heard that there were some years and models that have had problems.
    Does anyone know what those years and models are?
    thanks
    Feb 2012
    Spring City,Utah
    What model and year are you looking at?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Nov 2012
    North Las Vegas, NV
    The newer the better.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2016
    clark county indiana
    Default fire brand ussoildier
    wasn`t this spyder in the photo , and another one , caught burning , was the gas cap effect , they recalled the gas caps or something too this effect ?
    minnesota
    Please don't take "ussoldier's" post seriously.
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    Like any mechanical device there are almost assuredly issues.
    I believe that the 2012 models had some serious issues with gas caps, resolved with replacement.
    The 2013 RT had an issue with heat management, I think that there were four of them that caught fire, this was resolved by a retrofit from BRP that worked very well.
    Some of the 2014 and 2015 models had an issues with a DESS code that would lock you out of the bike completely, after a tow and some changes in the progrem it was fixed.
    Having said all of that, you have no worries if you get the VIN and check with BRP to see if the changes were done, if so go for it.
    Though you will still hear folks on this site tell you that the '13's are a scorching hot death trap, NOT TRUE. The will tell you that they had the DESS error, the tow and three attempts to fix it and no way run totally paranoid about going more then 50 miles.
    Check the forums section under Fo Sale or WTB and you will find some good bykes.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Default Find the best deal....
    There was only one year with major problems but again not all of them. BRP made the nessesary changes and all is good with the models out there today. You can and should check with the vin# to see all changes and updates were made to any one you find but as always the newer with low mileage is your best choice. Most spyders out there have been well taken care of and you will do well with any of them....happy hunting/shopping..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    It all sort of depends on which model has you most interested...
    By the way:
    The RS models from about 2011& 2012 were very good: we heard almost NO complaints about them!
    The ST models: anything 2014 & newer should be fine...
    RTs: 2012 was the best year for a 998 bike... unless you find a 2013 that has had ALL of the heat attenuation protocols performed... If that's the case: pop for the 2013
    In the 1330 bikes: You probably want ot look at something 2015 and newer... but none of the problems with the 2014 bikes were all that bad...
    As far as the F3: anything 2016 and newer should be fine!
    Happy shopping!
    Bob D. gives about the best description covering all the years.
    I have owned two GS/RS with the 998 engines. 2008 and 2009.
    Have owned three RT's. Two with the 998 and one with the 1330. 2010, 2011, and 2014. Total of over 130,000 Spyder miles.
    No F3's. None have been problematic for me. I prefer the 1330 to the two cylinder. Better gas mileage (10+) per gallon, quieter, more torque, and longer service intervals.
    There have been some mfg. glitches, but they also seem to be mostly solved at this time. A history of the VIN on any machine you purchase will tell you if you have a good one or not.
    Let us know what you decide.
    Jun 2015
    Ritzville, Wa
    Default Heart breaker
    Watching your Spyder burn down to the axles would be a heart breaker for sure.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
