Thanks Thanks:  95
Likes Likes:  95
Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 141
Thread: MAGIC MIRRORS
  1. #101
    Eponymous Member Bob Denman's Avatar
    Grahamsville, NY
    Thanks, Russ!
    Now it's time to wait patiently!
    Tick... Tick... Tick...
    2010 RT A&C .............................. 2014 RT Limited.
    (Gone; not forgotten!)
  2. #102
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    Default Sticking
    I hope the box doesn't stick to the conveyors etc during the shipping process from the strength of the magnets??
    This can happen from my experience.
    The he package is indeed magnetic but I have posted to oz and they all arrived
    the box you see goes into another bubble wrap post pack for some protection and I tested magnetism after fully packaged and yes there was some pull evident
    if I have to further wrap the pack then this will put it over the .5 kg magic figure,it's right on the borderline now....this will add to the cost of the product
    so here's hoping it all goes well
    i will look into better boxing re polystyrene when time permits but I am a FIFO worker and I needed to get these kits out to buyers a sap so was really cramped for time
    thanks. Russ and brenda
  3. #103
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Question
    Nothing here for me...
    Should I be worried?
    I did not get an email either and my order number was Order #920 was placed on January 25, 2017 and is currently Completed.
  4. #104
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Quote Originally Posted by SpyderCruiser View Post
    I also ordered on February 25 , 2017
    And did not get an email
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
  5. #105
    May 2015
    Tasmania
    Default Completed
    Hi louis....you are def mailed as yours was the first order received
    you used the word "completed". That's what the email says when you get it
    hi wilson
    you are def mailed
    i don't know why you didn't get confirmation
    thanks. Russ
  6. #106
    May 2015
    Tasmania
    Default interference
    Quote Originally Posted by Spyder_Cowgirl View Post
    Possibly silly anyway. With the strength of these magnets and their proximity to "electronic things" on the byke .... any chance of something going awry with some internal circuitry? I am especially interested in the CB ..... about to have mine replace a SECOND time (two bad units on a 2016 after the CB on my 2012 was nearly flawless).
    BTW, I REALLY like these Magic Mirrors ... I have broken, or severely bent, pins on both my 2012 and 2016 RT. Looking forward to ordering my own and doing away with that spooky set of "SMACKS" required to remove the mirrors now.
    Thank you for the response ..... Ann
    hi ann
    question not so silly
    this was raised by noboot...you could pm him to get his answer(think it was his radio tho)
    JRWW may have had issue with his senna but not sure (i posted his findings in feedback)
    Peter Aawen gave an informed post on how the maggots cant interfere with anything
    my answer is to get rid of the CB and keep the maggots
    But if you do buy and there is a problem re interference or any other thing youre not happy with then return them for refund
    thanks for raising the issue
    russ
  7. #107
    Grahamsville, NY
    Hi Russ!
    After watching the installation video enough times to feel comfortable about the process; I only have one question:
    Can you describe (Or take pictures of...) how the tether actually hooks to the mirror?
    It's the one thing that Ihaven't got fifured out yet...
  8. #108
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Hi Russ!
    Bob
    This video may well answer your question
    https://youtu.be/El3zoQXBQjk
    He has a few videos Ref the Magic Mirrors - Do a search on you tube for Russell Culley
    Eddie Sheppard
    Reading uk
    Get a Spyder - See the World
  9. #109
    May 2015
    Tasmania
    Hi Russ!
    one thing i forgot to mention
    when affixing the tether to the top tupperware screw
    the left side comes off the screw at 7 oclock
    the right side tether comes off at 5oclock
    just route both tethers in front of the top magnet and low
    if the tether is too short it wont allow the two bottom spigots to enter
    the tether has to be kept short so mirror dosent strike the tupperware if it separates from the bike
    also if its too long it can sit on top of the magnet reducing its pull
    may be better to leave the tether til last
    fit the mirror and try it a few times and when youre happy its good then fit the tether
    thanks russ
  10. #110
    Grahamsville, NY
    I see how you have the tether hooked to the bike; I'm curious about it's attachment to the mirror body...
    Or does it just snap onto the wiring; right below the connector?
  11. #111
    Aus, Sth Aust, Adelaide Hills
    Attaching the tether to the mirror will become fairly obvious when you have both in your hands. The tether has a two pronged clip on the mirror end that you hafta squeeze together & slip into the small hole that is already there on the mirror, then release the clip so the prongs can spring out & grab the sides of the hole & it's all done. Fitting the body side of the tether is just a matter of slipping the loop under the indicated screw head & swinging it into the appropriate 7 or 5 position before tightening that screw up.
    It's all pretty self evident, fairly straightforwards, & not in anyway difficult once you can actually see the bits rather than trying to imagine or exrapolate from the vids exactly what they look like/how they function or connect - so it's probbably best to wait until you've actually got the kit & have had a look at it and you've watched the vids with the appropriate bits in hand before you start getting too worried or the least bit concerned about how difficult anything might or might not be - no-one that I am aware of has had the slightest difficulty in installing these Mirror Magics yet. That's not saying no-one will ever have difficulties; after all, we all come from different backgrounds & have different skill sets, but I'm pretty sure that fitting these is straightforwards enough that it's certainly not worth worrying about any of it BEFORE you actually get the kit & can watch the vids with each of the appropriate parts & the instructions in front of you. Russ will be available (by phone?) to help if necesary & if you get desperate you can always drop me a message/email & then read the resulting epic reply! I might even be able to do some individually tailored pics, but like Mike/Blueknight, only if absolutely necessary!
    The first batch shouldn't be too far away by now, & then most of your questions will be answered or at least made redundant. And then I'm sure it won't take you too long to fit them up, after which there's a good chance that you'll spend some time just pulling your mirrors off the Spyder & letting them click back on just cos you can - if you're anything like the rest of us!! I did suggest that Russ might want to add that 'playing time' to his fitting instructions, but he thought that might be going a tad too far?!? I dunno why, everybody who's got em so far has done it!!
  12. #112
    Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Feb 17 #993 No email yet
    2014 RTL SE6
  13. #113
    May 2015
    United States
    Quote Originally Posted by DriftersWay View Post
    I didn't get an email but Russ confirmed that my order shipped.
    I'm thinking that anybody who didn't register on his site won't get an email.
    I checked out as an guest.
  14. #114
    May 2015
    Tasmania
    Quote Originally Posted by beefybudds View Post
  15. #115
    Active Member ceyer69's Avatar
    Jun 2015
    US
    Default Completed
    Hoping I'm in there as well. Charles Eyer
    Quote Originally Posted by merlot View Post
    hi wilson
    you are def mailed
    thanks. Russ
    2015 SE6 S
    Lamonster Web Pegs
    General Altimax RT43 Rear Tire
    Lamonster LED Headlights and Fog lights
    Baker Wings
    Bajarons Sway Bar & Links
    Bajarons Spring Adjusters
    Custom Dynamics Fender, Bright Sides and HMT Brake Lt
    Zumo 590
    CB
    Spyder Mudflap
    Lamonster drink holder
    Foam Grips
    Billet Axle Covers
    Stebel Air Horn
    SpyderPops Bumpskid
    SpyderPops belt guard
    SpyderPops Kotte Grills
    TriCLED LED Driving lights
  16. #116
    Grahamsville, NY
    [QUOTE=Peter Aawen;1237382]Attaching the tether to the mirror will become fairly obvious when you have both in your hands. The tether has a two pronged clip on the mirror end that you hafta squeeze together & slip into the small hole that is already there on the mirror, then release the clip so the prongs can spring out & grab the sides of the hole & it's all done. Fitting the body side of the tether is just a matter of slipping the loop under the indicated screw head & swinging it into the appropriate 7 or 5 position before tightening that screw up.
    Thanks, Peter; That's exactly the information that I was looking for!
  17. #117
    Very Active Member oldguyinCT's Avatar
    Nov 2013
    Weston, CT
    Boy, we are like a bunch of kids waiting for Santa to come down the chimney.
    A Wise Man Once Said, "I Should Ask My Wife"
    Pearl White 2013 RTL SE5 & RT-622 Trailer W/Extra Brake & Running Lights, Comfort Grips, SmoothSpyder Belt Tensioner, Rivco Dual Flag Holder, Show Chrome Luggage Rack, Don't Eat The Mud Mudflap, Spyderpops Missing Belt Guard, BajaRon Sway Bar, Links, Plugs, & Wires, Airhawk R Seat Pad, Large Brake Pedal, Amber LED's On Mirrors, Shorty Antenna, Guardian Bells, WOLO Air Horn, Garmin 660 GPS ,Sena Bluetooth, Ram Smartphone Mount, Lidlox
  18. #118
    Grahamsville, NY
    Quote Originally Posted by oldguyinCT View Post
    That reminds me...
    He's always watching!
    And the inevitable result...
  19. #119
    May 2015
    Tasmania
    Quote Originally Posted by ceyer69 View Post
    Charles eyer......mailed
    just a heads up
    if you asked for a different mailing address in the extra comments box then for sure I didn't read it
    all adds were taken from the primary address supplied
    hopefully no one else will be inconvenienced by this oversite on my part
    in future I will open up all buyers info and act on it
    thanks. Russ
  20. #120
    Nov 2013
    Weston, CT
    Ordered 2/10 #972, no Email.
  21. #121
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    WC922 Jan.25,2017
    Happy Owner
  22. #122
    Active Member HayRog's Avatar
    May 2013
    Sacramento, CA
    Thanking Russ for his ultra quick reply to my PM
    Should have these babies in my hands early next week Can't wait, but I have to
  23. #123
    May 2015
    Tasmania
    hi allen
    website has you buying as "guest" so may be something in it
    russ
  24. #124
    May 2015
    United States
    hi allen
    russ
    Hello Russ - You should prevent people from checking out as a guest. This would prevent all the time your spending letting people know there items have shipped.
  25. #125
    Nov 2013
    Weston, CT
    hi allen
    russ
    Thanks, Russ. Any ETA?
