Page 2 of 14 FirstFirst 12345612 ... LastLast
Results 26 to 50 of 339
Thread: MAGIC MIRRORS
  1. #26
    Active Member ceyer69's Avatar
    Jun 2015
    Wake Forest, NC
    Default Thanks for the update!
    Can't wait to get mine! Hoping to get them before Spyderfest!
    Charles
    2015 SE6 SS
    Elka Stage 2 front and rear shocks
    Lamonster Web Pegs
    General Altimax RT43 Rear Tire
    Lamonster LED Headlights and Fog lights
    Baker Wings
    Bajarons Sway Bar & Links
    Custom Dynamics Fender, Bright Sides and HMT Brake Lt
    Zumo 590
    CB
    Spyder Mudflap
    Lamonster drink holder
    Foam Grips
    Billet Axle Covers
    Stebel Air Horn
    SpyderPops Bumpskid
    SpyderPops belt guard
    SpyderPops Kotte Grills
    TriCLED LED Driving lights
    Magic Mirrors
  2. #27
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    Default CUSTOMS QUESTION
    i have a question re declared value of item when it gets to customs
    i want the arrival of parcel to be seamless with no hold ups or additional admin costs to purchaser
    im using HS Tarrif numb 850511 and value at $120AUD
    the UK ive got covered but im interested in USA...CANADA...SWEDEN
    thanks russ
  3. #28
    Default WELLLLLLL NOW THAT YOU MENTION IT
    Quote Originally Posted by merlot View Post
    thanks russ
    Ask " no boots " He sends the aluminum " ARMS " to the USA all the time !!!!! ........ Mike
  4. #29
    Active Member NewYorkSpyder's Avatar
    Feb 2016
    Schenectady NY
    Default Customs Question
    Should be easy to do conversion to dollars (USA) $91.14 (Canada) $121.90 and Kronas (Sweden) 818.46 if the value is based on monetary exchange where its being shipped to.
    2019 Rally , GMUltra Violet
  5. #30
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by NewYorkSpyder View Post
    Yeah, but it's the monetary limit on goods that you are allowed to bring in before customs require a declaration and tax gets applied that Russ is interested in, NewYorkSpyder. In Australia anything over $1000 au (goods + shipping) requires a customs declaration and taxes are applied. The goods stay in custom's hands until that is all sorted, and it can delay delivery by a week or more.
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  6. #31
    May 2015
    Tasmania
    correct....and i was informed that the UK has a limit of 15 british pounds when VAT needs to be paid
    i think USA is the same as OZ but EU countries may be lower
    russ
  7. #32
    Sep 2013
    Knoxville, TN
    Default mirror mounts
    I hava a set on order since last month. Merlot has been GREAT at keeping me up to date on his anticipated deliveries. I hope to have my set sometime this month and will keep everyone informed on how easy or difficult the installation is and any special issues.
    Ravseren
  8. #33
    Active Member pwm's Avatar
    May 2013
    Knoxville, TN
    Quote Originally Posted by ravseren View Post
    Ravseren
    I would like to see when you get them installed.
    2017 F3- Limited
    F4 23" Windshield, Ultimate Backrest, Spyder Cuff, SpyderPops Bump Guard, Sena SMH10 Intercom, BajaRon Sway Bar, Baker Cup Holder, RT-622 trailer w/Spyder Pops Bump Guard
  9. #34
    Still waiting patiently...
    Will we be receiving a PM, or an email when the mounts are being shipped to us?
  10. #35
    Nov 2013
    Central Texas
    I think that with any "startup" business, there are always kinks that need to be worked out, and they may come up all at once, or one after the other. Once merlot has all of his ducks in a row, I am sure that the magnets will magically appear in our mailboxes. Although, if you have a steel mailbox, you might not be able to get them out!
  11. #36
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Quote Originally Posted by oldguyinCT View Post
    Now -- there's a thought ^^^
    Better change the flap on mine to plastic
  12. #37
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi oldguyinCT,
    Re: if you have a steel mailbox, you might not be able to get them out!
    A fellow I know in Switzerland ordered some magnets & they arrived at the same time as his new credit cards.
    You can figure out what happened.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
  13. #38
    Active Member wd8ajj's Avatar
    Jul 2014
    Las Cruces NM
    After doing my last oil change and removing the left mirror and not damaging my hand or mirror I hope to get them at Spyderfest!
  14. #39
    Dec 2013
    I really doubt you'll have any significant difficulties getting the Magic Mounts out of your mail box... The magnets will be all stuck together (with spacers between them) & then rolled/wrapped up in bubble wrap before being put inside a post pack - so the major magnetic attraction is going to be firstly to each other with the magnetic field radiating from the ends of the roll & then a weaker magnetic field radiating out around the sides of the roll. Besides, you'll still have those couple of layers of wrapping material between the magnets & anything else - so even if there IS a tendency of them to 'stick' into your metal mail box, the material around them should make it fairly easy to pick them up & take them out!!
    As for your credit cards.... sitting a mag stripe c/card on top of or under the package itself might not be such a great idea - but probably only a major issue if it just happens to have one END of the roll sitting very close to or on the c/card's mag stripe. It really doesn't take too much distance for c/cards to be safe from mag fields, & it isn't all that far from the sides of the roll that the magnetic field starts to drop off enough that it will have little impact on anything that's not too sensitive. So I doubt it'd effect your c/cards if they are in your wallet, in a tank bag, or probably even if they're in a wallet or bag sitting on top of the dash.... but you might not want to lay your c/cards out on top of the mirror itself!!
  15. #40
    Active Member Madincalif's Avatar
    Delhi,ca
    Default mirrors
    ............patiently (almost ) waiting for the package arrival
  16. #41
    Jun 2016
    ... Pete I wasn't being CRITICAL of Russ or the Foundation or His motovations...... but Donations to cure Breast cancer are 50 times more than what is donated to cure Prostrate cancer ....... just a thought ........ Mike
    Mike, I apologise unreservedly if I gave you the impression that I thought you were being critical. That wasn't my intent. I was just explaining the background
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  17. #42
    Jun 2016
    Quote Originally Posted by wd8ajj View Post
    Russ is based in Australia, wd8, so he is probably not travelling to the US for Spyderfest. I believe you will have to order them, but I'm sure he will confirm shortly.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  18. #43
    May 2015
    Tasmania
    i spent ten minutes bashing linnies(friend) right hand mirror and i certainly damaged my hand
    as soon as magnets post to me (should be tomorrow )i will inform
    when i post to you i will email your tracking number to you
    1st batch(enough for 100 kits) was ordered feb6..still waiting
    2nd batch ordered 8 days later(this was against my better judgement as until stock arrives i am unable to QC it)this batch coming from different supplier tho
    3rd batch ordered 24 feb(diff supplier again)
    thanks russ
  19. #44
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    thanks russ
    As with all our supporting vendors, you are making a big commitment to support our community. We commend you all for that. Good on ya!
  20. #45
  21. #46
    May 2015
    Tasmania
    bulk magets posted to me yesterday
    tracking says i receive next tuesday
    so if all goes to plan i can start sending kits the following monday march 20th
    hopefully all backorders will then be received by the end of the month
    thanks russ
  22. #47
    Hi Russ,
    Thanks for the update: I'm looking forward to installing them, and no longer dreading every time that I do anything to the bike that involves removing bodywork!
    (Which seems to be EVERYTHING! )
  23. #48
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    2022 F3 Limited , Monolith Black / Dark
  24. #49
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    That is good news. I'm in that first group and looking forward to getting the mirrors fixed. Thanks for the update, Merlot.
    Stan
    Happy owner of 2014 White RTS - SE6
  25. #50
    Nov 2015
    Mooresville, In
    Order mine
    Ride safe!
    2015 RT L , Red
