Looking for advice with stock seat and Utopia driver backrest.
I have a 2009 RS. I can not get a Ultimate seat due to passenger backrest and luggage rack. Brackets due not allow ultimate seat to fit. I have already tried. So my dilemma is this. I have a place in town that will rebuild my stock seat, adding gel for shock effect and memory foam for comfort. The upholstery place suggested I purchase the Utopia backrest and bring it in and they will work with it. I just talked to Utopia and she thinks I need to do one or the other. She doesn't believe there will be enough room to use Utopia with a built up seat.
What do you think? Has anyone used a Utopia driver backrest with a built up stock seat? Please, looking for some input.
Thank you.
Mike, once again you always come in and save my sanity. Do you happen to have any pics of the seat? Thank you so much.
UTOPIA BACKREST - SEAT MOUNTING PICS
Mike, I was able to upload thumbnail pics on our previous gas door post. I hope these will help someone else out. I am having a seat cover shop in Oklahoma build up my lumbar support and they will add gel and than memory foam over that. They suggested I go ahead and purchase the Utopia backrest so they can install it while doing everything else to my seat. But I became very confused after speaking to Utopia. So honestly, I still dont know what to do? Do you think the backrest will work if they build up my lumbar support?
Thanks again, I really appreciate your help.
Sheila
SEAT ISSUES
Sheila
S, everything I said in post #4 applies. However I may know more about the " UTOPIA " BACKREST than they do..... I don't know what / how the seat shop people are going to help with your LUMBAR .... a MTC seat isn't like a Car or Trk ...... I had the same issues and did this to my UTOPIA and it worked wonders ..... your backrest PIVOTS - look where the bottom of the backrest pad touches the upright bar .... I put a small block of hard foam ( anything will work ) 1" thick and taped it in place .... this will angle the PAD .... and push against your lower back ( LUMBAR AREA ) ... 1" may be too much or too little - experiment ..... it really made a HUGH difference in the way it felt ..... you may not NEED any changes to the seat it-self !!!! .... Mike
Mike, you are just a wealth of information. Thank you very much. I appreciate your help. I will go ahead and order the Utopia tomorrow. I will try the foam first with the back rest
