Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 126 to 150 of 223
  1. #126
    Invalid Emails
    Apr 2017
    AZ
    Quote Originally Posted by jaherbst View Post
    It's a motorcycle, use motorcycle tires.
    No it's not, technically. A motorcycle has two wheels and requires a rounded tire both fore and aft to corner properly. If you want some cheap entertainment watch the bar bikes (those with huge square tires in the rear) try to go around a corner sometime. And leave plenty of space between you in the event the rider is not good at rim-riding.
    Because the Spyder doesn't lean while cornering it can use a flat car-type tire quite easily - especially on the rear. The stock Kenda rear tire is exactly that - flat (or square, if you prefer).
    So long as the tire profile is the same as stock, the speed rating is sufficient for the use intended and the tire loading doesn't exceed its design specifications it should be fine to use a car-type tire on the rear of the Spyder.
  2. #127
    Default Motorcycle
    Quote Originally Posted by RinconRyder View Post
    Wrong - a motorcycle is anything your DMV says is a Motorcycle .....and you can't get any more Technical than that ..... just sayin ..... Mike
  3. #128
    Invalid Emails
    Apr 2017
    AZ
    I will let common sense and the long history of vehicle nomenclature define what is, and what isn't, a motorcycle.
    A motorcycle, to me, is a two-wheeled motor propelled vehicle. A vehicle with three wheels is a trike (or motor-driven tricycle if you prefer).
    I have found most DMV's are anything BUT technical.
  4. #129
    Active Member jegarh's Avatar
    Jul 2016
    maverick county, texas
    What ever happened to DIY? I haven't had to replace a tire yet on my 2014 RT SE6, but when I do I will get out my tools and do it just like I do on my motorcycles, my Ural, my Excursion, my transit and my Cat backhoe/loader. Did I miss the post by somebody actually doing it themselves? Putting Dunlop 606's on my WRR250 requires 3 arms. If you don't have 3 arms you improvise.
    intelligence is genetic. Stupidity is an acquired skill.
  5. #130
    Feb 2013
    Arlington VA
    Default Rear Tire
    Can anyone tell me if they think a Kuhmo Ecsta 225 50 R15 will fit a 2016 F3L?
  6. #131
    Mar 2013
    Oz
    Our dmv, VicRoads, calls it a Tri-Car - but we need full motorcycle license to ride it.
    There is no logic...
  7. #132
    Default ANYTHING BUT .....TECHNICAL
    .., Really, go down to your DMV and try to get your Spyder registered as a Tricycle, or Trike and see what happens ...................Mike
  8. #133
    Default DMV ?????
    Quote Originally Posted by loisk View Post
    Thank you for the correction ........ However I seriously doubt 99.9999 % of Spyderlovers on this Forum have the motor vehicle regulations of EVERY country in this world ...... memorized....... Mike
  9. #134
    Default Kumho tire
    Quote Originally Posted by The Wanderer View Post
    Yes , but stats show the Altimax is superior tire for about the same money...... but no matter what you buy any car tire on any Spyder only needs 18-19 psi ( rear tire not front )for optimum performance and comfort ..... Mike
  10. #135
    Invalid Emails
    Apr 2017
    AZ
    Our DMV won't register your rocket propelled unicycle either.
  11. #136
    Mar 2013
    Oz
    Sorry mate it wasn't meant as a correction - just a curiosity - spyder rules differ all over the world and I guess I occasionally chip in to highlight variances. Licensing, registration, all lighting, indicator style, etc
  12. #137
    Dec 2015
    South Carolina
    Default Front tire matching question.
    OK, I am getting ready to buy new tires. I have read tons of comments on replacing rear tires.
    I think i'm going with Yokohama S-Drive 205/55 R15, but my question is what are folks using on the fronts, if they have this Yoko on the rear.
    I have a 2012 RT SE5. I am not a real aggressive driver. Ride two up alot.
  13. #138
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    The reason "three wheels" is associated with motorcycles is because, back in the day, "three wheels" meant a motorcycle/sidecar rig.
  14. #139
    Invalid Emails
    Apr 2017
    AZ
    Quote Originally Posted by Fat Baxter View Post
    I'm not so sure. I've been around bikes my whole life and have never heard anyone refer to a motorcycle with a sidecar a "trike". "Hack", "rig" and "sidehack" yes, but not trike.
    When the modern trikes first came out virtually all states did not have any unique licensing for them and since they resembled two-wheelers they used the motorcycle endorsement - hence, became another version of "motorcycle". Some states have a special motorcycle license designated specifically for trikes.
    But, as virtually everyone on this forum who has ever ridden a two-wheeler already knows, Spyders (and by extension other trikes) are NOT motorcycles in that they have very different handling characteristics. About the only common thing is the riding position in normal flight - you sit ON a motorcycle/trike and IN everything else.
    Some states have a third definition for three-wheeled encapsulated vehicles calling them an "autocycle" but that isn't totally correct either since those vehicles are not at all related to a "cycle" but rather a different type of car. And in most states a motorcycle license is not required to operate them.
  15. #140
    Three wheel motorcycles predate state licensing requirements by many years. Since I don't know I'll ask. What did the American and German armies call their three wheel versions of motorcycles back in WW II? I'll bet it was 'motorcycle'.
    Cushman three wheelers back in the '50s were called motor scooters, the same as the two wheel versions.
  16. #141
    May 2017
    Mesa, Arid-Zone-A
    I am getting ready to replace the rear and have read this thread. Lots of good suggestions here. However, I am dismayed about dealers refusing to install a better tire on the spyder. I have owned many dozens of vehicles including a CanAm Outlander, a CanAm Commander and several Goldwing motorcycles. The dealers have always presented many different tire options from different tire manufacturers. My local BRP dealer is also my local Goldwing dealer (among other brands). They have never told me that I must install any particular brand of tire on my Goldwing. Why would they do so on the spyder? Make no sense. As long as a replacement tire meets or exceeds the OEM specs, there should be no issue. Does anyone know exactly what is going on here......?
    Semper Fi
  17. #142
    Houston
    What is going on here is a contract requirement between CanAm and Kenda requiring the exclusive sale at the dealerships.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  18. #143
    May 2017
    Mesa, Arid-Zone-A
    If that is the case, I believe it would be in violation of the Moss-Magnuson Act not to mention several free trade and anti-trust laws. But then, maybe Canadians can do things a little differently. If CanAm and Kenda want to be in bed together, I hope they make each other happy. I won't make it a three-some.
    Semper Fi
  19. #144
    Dec 2015
    South Carolina
    Default Fronts and rear
    With all this talk about what rear tire people have, shouldn't you just toss the OEMs and get General Altramax (or Yoko, or Bridgestone etc) all around?
  20. #145
    Quote Originally Posted by canamjhb View Post
    NHTSA requires that tires be labeled for the vehicle type the manufacturer has designed and tested the tire for. There are many brands of m/c tires designed and tested for two wheel m/c use. That's why your GW dealer doesn't force you buy a specific brand. Recognize that normal m/c tires have a bead design significantly different than car tires. Your GW dealer very likely will not mount a Michelin car tire on your GW, but he'll gladly mount a Michelin m/c tire on it. The Can Am tire is a hybrid, or in one sense, a bastard tire in that it has a bead design pretty much identical to a car tire. But no car tire manufacturer to date has tested and certified their tires to be used on any motorcycle. The Kenda is the only tire with a car tire bead that has been designed and specified to be used on a m/c, i.e., the Spyder and Slingshot. Tire dealers are required by NHTSA to install tires on vehicles that have been labeled for use on that type of vehicle. The only reason we are able to get car tires installed on our Spyder wheels is because tire dealers are willing to overlook the law.
    As far as contractual restrictions between Kenda and BRP, that may be. But a greater controlling factor is market volume. Kenda so far is the only tire manufacturer willing to build a low volume tire for the Spyder, and there is no economic incentive for them to sell them to anyone else but BRP.
  21. #146
    Quote Originally Posted by Indiana Ken View Post
    Most, but not all, front tires by Kenda have been decent performers, not stellar, not great, but decent. Decent enough that there isn't near the push to use car tires on the front. The front Kendas on my 2013 RT did all right for 25,000 miles plus. The ones on my 2014 RT had a continual pull to the right and I changed them out at 13k miles for Continentals.
  22. #147
    Jul 2011
    Cleveland, Ohio
    Quote Originally Posted by BoilerAnimal View Post
    The only real hard part (actually very easy after giving it a little thought) was getting the belt back on the rear sprocket. It didn't work for me quite like the video by Finless Bob. I had to loosen the bolts that are used to align and tension the rear wheel. Since I had good alignment and belt tension before starting this I needed to loosen it in a way that allowed me to get it back the same as before. So, before loosening the alignment bolts I used a white paint marker to put a match mark on each bolt and the frame. Then I backed off each bolt four full turns, slipped my drive belt on, then tightened the bolts four full turns. I got the tire seated fully to the rear and torqued the axle bolts to 96 ft lbs. My belt tracks just as before and appears to be properly tensioned. And I love my new tire!
    Ah, ah, ah, don't touch the Belt Alignment Bolts. Just Jack up the rear tire just enough to get the pressure off the Rear Shock. Remove one end of the Shock bolts. Now you can raise the rear of bike enough to take all of tension off of the belt and remove the Axle and Tire. Simple and no Belt Alignment problems.
    Chris
  23. #148
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Quote Originally Posted by No 2817 View Post
    Chris
    ok, if this is true, i can do this at the shop , by myself, and spare all
    sorts of agony? it cant be that simple. there was a video somewhere of this.
    anyone have it ?
    [joyce & irvin toms]
  24. #149
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Chris
    You can touch the rear wheel alignment bolts with no problems IF you match mark them FIRST and you TURN EACH BOLT THE SAME NUMBER OF TURNS. If you get confused and turn one bolt more than the other, you will have to readjust your rear wheel to get your belt tracking correctly.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
  25. #150
    May 2016
    Quote Originally Posted by irvin48 View Post
    anyone have it ?
    Here you go. https://m.youtube.com/watch?v=MWtbQPdKd8w
    2013 RT-S SE 5
