Results 1 to 7 of 7
    Feb 2015
    Sun City West, AZ
    Default 2015 RTL - Left Saddlebag comes open when Ryding.
    It just pops open while I am riding. Doesn't matter if it is "locked" or not.
    I shut it all the way. Test it. It seems tight but it still opens up when moving.
    There is nothing in the bag as I don't want to lose anything at 30 or 75 mph.
    Any Ideas?
    Jack
    RoadRunner
    Sun City West, AZ
    Jul 2014
    United States
    Sounds like the latch is not adjusted properly. The black cowling where the license plate is needs removed. Adjusters are there just below the latches. Check the hinges to make sure one has not broken.
    Feb 2015
    Sun City West, AZ
    Default Closed
    BRP replaced the top latching mechanism under warrenty.
    All is well.
    RoadRunner
    Sun City West, AZ
    Oct 2015
    Northern Michigan
    Mine does the same dam thing. Hmmm.
    Quote Originally Posted by jlknorst View Post
    All is well.
    All is well.
    Glad to hear that you're "Back on Three!" , and not leaving a trail of stuff along the way!
    Jun 2015
    Hampton Roads, VA
    Default Adjuster
    Hi,
    I tweaked my adjustment to fix on 2016 RTS. Remove three top screws of rear fender and pull down a bit, right behind is the cable under the latch. Next to the tail light is a screw adjuster built into the cable headed over the the left side.
    Steve
    Oct 2015
    Northern Michigan
    Quote Originally Posted by Stick View Post
    And mine does the same dam thing. Put rain gear all over the highway. Hmmm.
