Results 1 to 8 of 8
Thread: head light inop
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Default head light inop
    The other day my Canadian friends came over with one light light not operating, I found it was not the bulb , it was the plug burned up lucky we found a plug with wires to fix it at Auto zone good fixheadlight plug 1.jpgheadlight plug 2.jpg
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi jtoro1,
    Re: the plug burned up
    My first thought, without actually seeing it, is that it might not have been seated completely, allowing arcing within the plug.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    That would be my guess also...
    Glad to hear that you found the right parts, and soon had him "Back up on three..."
    Jun 2010
    Las Vegas
    The same thing happened to me and the light was replaced under extended warranty.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Feb 2013
    port st lucie fl
    Quote Originally Posted by JerryB View Post
    Hi jtoro1,
    Jerry Baumchen
    The plug was seated correctly but most likely it was arcing inside
    Dec 2013
    They hadn't fitted higher wattage globes to get better light output had they?? That 'melted connector' thing is something I've seen here a lot, especially on 4WD's, where owners have 'upgraded' their light output (via higher wattage globes) without upgrading their light wiring to suit the increased current draw.... The higher wattage means more heat wherever there's increased resistance, ie especially in the smaller or more enclosed connectors, & eventually they just melt....
    Default yes - but
    Quote Originally Posted by jtoro1 View Post
    If the plug was seated correctly - there shouldn't be any ARCHING ...... Mike
    Default MELTING
    .... On my RT I tried 100 watt halogens , and my plugs looked just like the above after 4 mos......... I did find CERAMIC replacements on E-bay for less money ( by 1/2 ) that what I could get normal ones at the Auto parts store ........ Mike
