Harley Sound
I'm just curious. Has anyone tried to make their 998 Spyder sound like a Harley? It seems like that with the correct muffler that it maybe could be done or at least close, after all the 998 is also a V Twin, maybe not the same angle. This is just one of the many random useless thoughts that rattle around in my head at times, and I'm not sure why anyone would even want to do this.
Ed
They told me not to give up on my dreams, so I went back to sleep.
Champagne 2017 RTS SE6
Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
be like trying to make a 65 beetle sound like a 68 hemi cuda.
Just take off the muffler it will sound just like one then..
The 998 is a high reving multi valved overhead cam motor. The Harley is a slow turning,2 valve, OHV. They will never sound the same.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Well....
You could match the decibles eliminating the Y pipe and muffler or maybe match a non-harley type or even a parallel twin...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Never going to happen. It is impossible as the 45 degree twin has a completely different firing order than the 60 degree v twin
Sent from my Nexus 6 using Tapatalk
Harley Sound
It is impossible because of the degree difference in the 2 engines. one is 45 degree and the other is 60 degree. The 45 degree engine firing order is #1 cylinder first then the #2 cylinder. On the 60 degree engine the #2 cylinder fires first, SO, basically, the sound would be backwards. PLUS, 45 degrees goes brooooom, and 60 degrees goes roooooooom, HUGE difference. Plus the spyder is too fast for the Harley sound, that is why it has aerodynamic body panels on it. The Harley sound, well, not aerodynamic and therefore multiple things start to fall off giving you the HARLEY SOUND. Thats all I have.
This is a joke, right?
If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
i love the way a Harley sounds, all you need is a 12 volt lighter plug, and go to 2:12 on this video
NO BIKE AT THIS TIME
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Hi Cuzn,
I wonder how that would work, if you plugged it into the top trunk power port?
Exhaust
The closest I have seen to a Harley Exhaust on a Spyder is the exhaust from Spyder Attitude (Spyderattitude.com) a sponsor to this site. They have sound bites there of their exhaust if you want to hear what their exhaust sound like.
2012 RTS
Why?
why would you want to? Once in a while I ride with a bunch of them and they are so loud . I looked down at my speedometer and discovered I was doing 80 in 5th gear because I could not hear what my SpYder was doing😬
Mike Campbell
Amarillo, Texas
2015 RTL "intense red pearl"
I don't want to I was just curious if anybody had tried. I like the way mine sounds stock.
Ed
What's the rarest Harley out there?
The one that still has the stock exhaust system in place!
I had one of those along time ago. The wind noise by itself is enough to cause hearing problems.
Between riding and former employment I have some hearing issues already.
Ed
My hearing has become a bit more "selective" over time also...
That means my '17 TriGlide is rare. WOW!!!!!! And I just got it.
I put on the dual's from Spyder Attitude along with Lamonte's pipe. I can drown out Harley's if I want too.
2017 F3- Limited
F4 23" Windshield, Ultimate Backrest, Spyder Cuff, SpyderPops Bump Guard, Sena SMH10 Intercom, BajaRon Sway Bar, Baker Cup Holder, RT-622 trailer w/Spyder Pops Bump Guard
just go purchase a dozen Harley t shirts and few Harley tattoo's and then park your bike in the garage and don't ride it much.
you'll save money in the long run
2015 RT Limited Intense Red Pearl
