Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: HELP fAST
    Feb 2016
    HAWTHORNE nj
    Default HELP fAST
    Pirre contact info spyder accessories link or a phone number please.. my hitch shaft came apart don't know how I made it home.
    Default OR......🤔
    You can reach him through spydertv.com...
    Feb 2012
    Spring City,Utah
    Try this for a phone number. Pierre will want to hear about your problems.
    450 586 9608
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2016
    HAWTHORNE nj
    Default Its crazy
    I went out for a ride and returned home and I smelled rubber, I found the shaft had sheared off on the right side. Yes I am talking about Pierre, He is a cool guy I am sure he would want to know what happened. But I need a shaft and nut along with the cotter pin asap...
    Jul 2014
    United States
    Quote Originally Posted by MOSESS View Post
    I went out for a ride and returned home and I smelled rubber, I looked further and found the shaft had sheared off on the right side. Yes I am talking about Pierre, He is a cool guy I am sure he would want to know what happened. But I need a shaft and nut along with the cotter pin asap...
    Is that on a F3S?
    Feb 2016
    HAWTHORNE nj
    Default Hi there.
    Hi Doc this is on a 15 RT-s. When I arrived home and saw the bolt sticking out the left side I very upset but glad I made it home, this could have been a very bad day for me, Has this happen to any one else ...
    Jul 2014
    United States
    Wow, that is very rare. Never heard of it happening before. Who installed the hitch?
    Feb 2016
    HAWTHORNE nj
    Default okay
    Pierre installed it at spyderquest . while he was doing that I was looking at your bag that you had mounted on your rack. Any way I don't know if this is a freak incident but scary all the same. if that shaft had come out while I was riding , You know the rest I don't think I would be here .
    Jul 2014
    United States
    Well, thank God you are OK. Might want to have the dealer check for possible bearing damage. You may be OK, but I would still check. If memory serves me correct, that is torqued at 180 ft. lbs., I think.
    Default SHAFT & NUT
    Try Home Depot , Lowe's or Fastenal ( in that order ) they will have the size threaded rod you need and the LOK-Nuts ,..... you won't find a Bolt that long ........ Mike
    Sep 2014
    USA
    This would be the hitch axle and not the wheel axle correct?. If so it makes me wonder why it broke?
    Jun 2015
    Ritzville, Wa
    Default Seems simple
    Wel that certainly seems simple enough to install.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Now that I've seen that video of his hitch being installed: I LIKE it!
    May 2013
    Apex, N.C.
    That (no axle removal) installation is very much like the one for the show chrome hitch. That is the reason I wanted one that did not remove the axle. I did see one on this forum where the rod within the axle came out, but the axle rod itself, remained intact. I check mine every so often (visually), just to make sure the nut on the end of the rode is still in place. The problem with the one on the show chrome kit is that they actually suggest using a lock washer on the bolt side and the nut side. When I did that, the lock washer on the head of the bolt split and fell out (because the washer was too close to the size of the hole in the hitch). This allowed the rod to shift towards the nut side and the nut could have loosened. I removed the rod and put a larger, thicker washer at the head of the bolt and have not had any problems since. I do not pull a trailer, but I used it with Doc Humphries rack and it was perfect.
    Feb 2016
    HAWTHORNE nj
    Default Crazy
    After talking with Pierre I did an inspection and every thing appears to be fine. He is heading to his vendor, great guy, any way ill test ride the Rt later today .Ill keep you informed as this develops.
    Jul 2014
    United States
    I realized last night we were talking about the inner bolt and not the axle bolt. I don't think they are a hardened bolt. Still hard to believe that it broke. Please disregard my previous post. That was for the axle bolt and nut.
    Wonder what a bolt like that would cost? And, all thread is pretty soft. Don't know how it will hold up over time.
    Is there a way to figure out what grade that bolt is, and perhaps find something tougher?
    Jul 2014
    United States
    Being a mechanic for so many years it has become a habit that if I pull a bolt out I will look at the grade and as near I can remember it had no grade markings.
    If the bolt isn't marked: can you draw any inferences from that?
    If you were picking a bolt based upon it's grade: what would you choose?
    Sep 2014
    USA
    it looks like the same bolt as the BRP hitch uses. The one post above mentions broken lock washer which could create a gap and cause the axle to shift until broken.
    Just speculation on my part.
    Default THE OP PROBLEM
    Post #11 answered this problem ............. and because there is little or no stress on ROD it can a grade #5 ,,, 5/8 dia. using Lok-nuts .......... this rod goes thru the OEM axel ..... the AXEL is what's taking the load ..... the rod only holds the Hitch plates firm to the swing arm sides .......... Mike
    So if it's a Grade 5: is there any extra peace of mind afforded, by going to a Grade 8?
    Jul 2014
    United States
    Most all thread is no grade or 1 or 2. I did find this:
    http://catalog.interstatethreadedpro...ds-grade-8-atr
    If that was a good steel I would go with this if it wasn't too expensive.
    One factor to consider is unless you get stainless steel (low grade) since it is not anodized it will rust. Painting with a Rustoleum might prevent that. Here is a link for more info on all thread than you will ever need.
    Very Active Member StanProff's Avatar
    Jun 2011
    Jonesborough Tennessee
    To me the grade bolt would be important as well as the diameter of the bolt. I have never heard of this happening on a can am hitch. Anyone else? I believe the can am factory hitch is sleeved where the bolt slides through. I can't see it this one is sleeved or has edges where the bolt slides through.
    Happy Spyderlovers
