2015 F3 Error Codes / problem
We are (new to us) Spyder owners. We just purchased a 2015 F3. We took delivery of it on Friday night. When we got home with it a code popped up and said "EBD FAULT BRAKE FAILURE" I had parked on a slight incline and after doing a google search I moved it to a level spot and after a few minutes the code went away. I also checked the brake fluid and it was full, just a little dark colored. Well, Yesterday we went for about a 50 mile ride and the code came back up again. I called a couple of dealerships and talked to the service managers to no avail. Neither of them had seen that code. I read the manual and checked for an error code and it showed "O C 1048". I checked the F3 this morning and it seems fine. Do any of you have any ideas what it could be?
Thanks in advance
Steve
Well....
Can't find that code. Brake failure come from a series of places....check
Brakelight switch
Brake Light bulbs
Brake pads
Brake fluid even the slightest level change will affect it.
Make sure you are not ryding with your foot on the brake
Park brake issues
Also make sure you remove the key and walk away so the vomputers reset and the codes clear.
If they keep coming back see the dealer..
2012 RS sm5
Brakelight switch
Brake Light bulbs
Brake pads
Park brake issues
It was taken back to the dealer today. I called to check on it and was told that they could not figure it out. They sent the file with the codes showing back to the manufacturer to see what they can find. Hopefully they can hurry up and get it fixed.
