Results 1 to 5 of 5
Thread: Input
    Active Member ornerydog7's Avatar
    Sep 2011
    Allen, TX
    Default Input
    I live in Allen and have a 2011 RTL / SE5 that needs to be serviced. There are three dealers in the area, Richardson, McKinney and Greenville. Which would you recommend? Thanks.
    2011 RT LTD /MODS: Seal Floorboards, Elkas, SpyderPops Bump Skid and Block off plate, HMT Brake light, BajaRon's sway bar, Heim Links, Diamond R's passenger armrest, Utopia driver backrest
    Very Active Member TexasSpyder's Avatar
    Apr 2012
    USA Andrews, TX
    I have used Lewis Powersports in Greenville with good luck on my 2012 RTL SE5.
    2016 F3T Magnesium Metalic : Smooth Spyder Dual Backrest, Lamonster LED Head lights and Fog lights
    Dec 2016
    Port Richey, FL
    Heard good things about Greenville, but haven't used them.
    I use Broadway Powersports in Tyler. I'm pretty impressed with them so far.
    Active Member IVSSpyder's Avatar
    Apr 2015
    Corinth, TX
    I bought mine from Freedom and have only been there for an oil change but I've heard good things about them. They do have a factory certified tech.
    Greenville Tx
    Freedom Powersports is the best one by far. I live in Greenville and bought my Spyder from Louis Powersports but Freedom is the only one that will install car tires and think of the customer first. If you are a member of Spyder Ryders of East Texas, they give us a 15% discount on Parts, Accessories and Labor because they are our sponsor. I was told that they also sell car tires of the brands that we use the most.
    Free to join, small contributions for expenses are accepted.
    https://www.meetup.com/Spyder-Ryders-of-East-Texas/
    2017 F3 Limited
