Page 1 of 2 12 LastLast
Results 1 to 25 of 33
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Default spyderfest newbie [maybe ] ?
    if we wait till april to get a motel room can we still find one? trying to figure
    out how to get there and a trailer. have an 07 mountaineer with the v6 and
    am looking at a 5.5 x 10 aluminum utility trailer to build a quick enclosure on just to keep out of
    the elements. think it would be to much tongue weight with an rt ? this is a class 2 factory hitch.
    used to haul a show car on an 18 ft trailer but i had a truck and equalizer hitch then.
    its a little over 500 miles for us to get there according to mapquest. thanks for any
    help. never been to a large event before,just mercury shows.
    irvvin and joyce toms
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Oct 2015
    Iowa
    Not sure that the trailer you are talking about getting is actually big enough to enclose. A friend of mine uses a 6x10 tiltbed open traller and had to modify the front rail to enable getting the bike forward enough to get sufficient weight on the tongue. 5.5' is 66" with a bike that is approximately 62" wide. IMHO too tight a fit.
    Bryant, Arkansas
    There will always be a hotel room somewhere close, but the guest hotels fill up fast and have the most fun. Why not Ride you Rt to Spyderfest?? you could make an adventure out of it by riding halfway and spending the night at a hotel then finish the ride the second day.
    Which ever way you decide you will enjoy Spyderfest.
    Cruzr Joe
    Default ROOMS
    I recall reading somewhere Springfield has over 5000 rooms ...... Mike
    Why not see if you can reserve a room now? Just make sure that you know exactly what your rights are, if you cancel...
    Jan 2015
    southern WI
    We use our 6cyl ford escape and does ok for the 550 mile trip. We pull our RT on an open 6x10 alum trailer. As for rooms, you'll find one...it might not be as close to the fairgrounds as the host hotels, but you'll be fine. I'd be willing to bet that regardless of where you stay, there will be at least a handful of Spyder ryders there. I think you'll be happy with trailering. It offers a bit of freedom and ease....
    2021 RT Limited
    2016 RTS , Pearl White
    Dec 2014
    Lee's Summit, MO
    As Bob said, go ahead and get a room now. You want to check with the host motels and if nothing else get on their wait list. Rooms will probably open up closer to Spyderfest as you will have folks that find they need to cancel. I had a room reserved two years ago and due to family obligations my cancellation opened up a room. As for trailering your Spyder, keep in mind that a RT is only 1k#. If you have it set on the trailer right the tongue weight should not be that bad. You should be fine for the trip to and from Springfield.
    ( Gotta say it...)
    Why not ride the Spyder to Springfield??
    It's not that far: just under 500 miles.
    May 2016
    mt morris il
    just where in springfield are the fairgrounds and host hotels. not a lotta info for us newbies.
    Nov 2016
    Palm Desert
    We talking Ohio? Any in California?
    Dec 2014
    Lee's Summit, MO
    Quote Originally Posted by irvin48 View Post
    The fairgrounds(Ozark) are on the north side of Interstate 44. Can be reached from Hiway 13 or Hiway 65. The host motels and others are on Glenstone Ave which runs north/south thru Springfield somewhat on the east side. Pitbull Powersports is on Glenstone also. Springfield is pretty easy to get around in. Hope this helps.
    Idaho
    Google maps is your friend here. The fairgrounds is Ozark Empire Fairgrounds. Do a search in Google maps for the hotels and click on directions and put in the fairgrounds.
    2014 Copper RTS
    May 2016
    mt morris il
    thanks guys and gals.
    Would you like to know how I found the Fairgrounds?
    I just followed the Spyders!
    I'm not joking! It took me a couple of tries to figure out how to get there!
    But it was worth it!
    Sep 2012
    Junction City, KS, USA
    Your 5.5' trailer is too narrow. I'd suggest ryding to Spyderfest unless you just want to get a new trailer.
    Any hotel on Glenstone Ave north of Pitbull would be a good idea.
    Waynesville, Missouri
    It appears that the two host hotels are booked as of right now. There are still several hotels to choose from and there will most likely be spyder ryders at them all by the time Spyderfest comes around.
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    Quote Originally Posted by PrairieSpyder View Post
    Hate to steal your thunder, but I have a 5 1/2' wide by 10' long trailer (from Northern Tool) that I have logged thousands of miles toting my 2014 RT Limited all over the greater Midwest without any problems.......
    BIG F
    May 2016
    mt morris il
    Quote Originally Posted by Big F View Post
    BIG F
    is yours a carry on brand. thats usually what they sell. got a pic with the rt on it.
    tractor supply has a 6x10 aluminum trailer to rent. think i'll bring it
    home and try it before making a 2000 or more mistake. any way to tarp this to keep some
    of the weather off of it in transport . without beating it to death.
    It's actually better to trailer it uncovered and give it a bath; than try to keep a tarp from beating your painted surfaces into submission.
    Default COVERS - & TRAILERS
    Irv, do NOT cover it when you trailer. It's like rubbing sand on the paint . The only thing that works is the professional plastic wraps that are put on new cars and boats when delivered to dealers................... Mike
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default What kind of trailer...
    Quote Originally Posted by Mazo EMS2 View Post
    (snip) We pull our RT on an open 6x10 alum trailer. (snip)
    ...do you (Mazo) have? We need to get one....
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    May 2016
    mt morris il
    yes i understand. i open trailered my mercury cars to national show for years.
    built a v front on the trailer that directed the rain over and around the car.
    worked well when moving.[ not so well when stopped]. im pretty anal about NOT getting
    the spyder wet. day rides only. wife wishes i treated the house like my vehicles.
    and , no, our butts and backs wouldnt like a 500+ jaunt one way.
    shoulda started planning sooner.
    ...shoulda started planning sooner.
    Better late, than never!
    Jan 2015
    southern WI
    Quote Originally Posted by BigGuy66 View Post
    Jim
    Our trailer is really nothing specific. It's just a 6x10 aluminum utility trailer with a rear ramp, much like many people use for atv's and mowers and such. (2500# capacity) It has rails that are about a foot above the deck. I bought some extra tie down loops so I could put them where I wanted them(2 at each wheel, one directly in front of each wheel and one directly behind each wheel, with a tie down strap over the tires.) Just like the rear tire is shown in the pic. Works perfect, and cheap and easy to do. We paid $1400 for the trailer.
    2021 RT Limited
    May 2016
    mt morris il
    Jim
    yeh. some pics of your small haulers would be nice. we cant all afford the fancy stuff.
    married almost 45 years and could barely afford the rt for retirement gift to us. this
    is not a poor mans machine as i am finding out.
