Battery Replacement
I may need to replace the battery on my 2012 RT-SE5. I have some questions regarding this procedure:
1. when the battery is removed, will I lose stored information like mileage?
2. is this something I should do, or should I take it to the (very expensive) dealer?
3. if I do the replacement, what's a very good battery to use?
4. I don't have a battery charger (just a tender), so I'll have to have this done where I buy the new battery...how can I be sure they've properly charged it? (I read that improper charging can reduce the life of the battery a lot).
Thanks in advance for your advice and expertise! I'm still a "newbie owner"...
Let's see....
There are videos on how this is done....
You will only have to re-set you time, temp C/F, speed mph/kph
Yuasa is still the best, imho, and comes charged but put it on the tender to make sure
Be sure to get the battery that is already filled and not the fill it yourself type. Cheapcycleparts.com or online they are cheaper
Watch the videos and decide, seach here and you tube...
2012 RS sm5
1. when the battery is removed, will I lose stored information like mileage? No
2. is this something I should do, or should I take it to the (very expensive) dealer? You can do yourself if handy
3. if I do the replacement, what's a very good battery to use? Stock is fine
4. I don't have a battery charger (just a tender), so I'll have to have this done where I buy the new battery...how can I be sure they've properly charged it? (I read that improper charging can reduce the life of the battery a lot). Any good battery store or dealer will be fine to get a battery. Batteries are normally charged and don't need to be charged unless sitting around for longs period of time.
See above in red. Hope it helps some
The stock battery for that machine is the Yuasa.
http://www.yuasabatteries.com/batteryprint.php?id=191
It is an AGM battery, which is required over a standard flooded cell battery, because it lays on its side. If you don't have an AGM charger, and don't want to buy one, then you'll need to buy the battery already filled and given the initial charge. Otherwise, the ones you see on line have a -BS designation. Meaning bottle supplied. You fill and charge them yourself. The initial charge is important to getting rated life out of the battery.
You could price the battery from your dealer and then install it yourself if you want.
Doug
”Freedom is not a loophole”
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
There are a lot of myths about charging a new battery. A bottle filled battery, filled in the store must be charge at a slow rate before installing the caps for a period of time. That is how you get the freshest battery for your Spyder. There are also factory filled batteries. They do not need to charged unless they have been sitting around for a while. Buying one of these makes sure the battery has been prepped properly. But you really don't know how old it is so risk not having the freshest battery.
https://youtu.be/Xpg10yp4duo
2018 F3 LIMITED
Good to Know!
That's good to know. Reseeting those things is pretty easy. I had to reset them when I got the bike. I can probably do the battery swap myself, especially if I can watch the video first to see about any tricky parts. I'll check out cheapcycleparts.com and the suppliers listed on this site. If they can give me a decent deal, I'd rather send the business their way because they help support this site. Thanks!
Good video
Originally Posted by Highwayman2013
Not a hard job at all.
Good video, but I hope I don't have to remove the side panel, mirror, etc. on my 2012 RT. That's a bit more than I'm willing to risk... Maybe, just maybe my 2012 has enough room, and access to the positive terminal so I can slide the battery out. I'll pull the battery cover and have a look. Thanks!
Yup, It Helps a Lot!
Thanks! I'll probably give a try myself...just hoping I don't have to remove half the "tupperware" panels to get at it. LOL
You probably will have to remove the mid panel like my video shows.
The trick I show in the video shows how to remove that panel without removing all the front ones and mirror.
Bob
2011 RT-S SM5 - Black
Do you have a cigarette lighter on the bike, if so go to an auto parts store and get a 9 volt memory saver. Codes do not go away, nothing needs to be reset.
Sent from my XT1635-01 using Tapatalk
