Results 1 to 25 of 25
Thread: Weird tire wear
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    Default Weird tire wear
    Good evening to all of you who are more in the know on the Spyder. My reat tire is is worn to the wear bar on the wear bar on the left outer tread, all the rest are good.this is on an 09 GS SE5 the tire is the Arachnid running 30 psi. Any one seem this before the rear was installed at a dealer approx 6500 miles ago the fronts were done at the same time they are wearing even and still have good tread. Any thought greatly appreciated
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
    Jun 2010
    Las Vegas
    I ran 3 Arachnids on the rear of my 14 RT and all of them wore on the outer edges - both edges. It didn't matter what tire pressure I ran they all wore the same. In my opinion Arachnid tires are just as crappy as Kendas.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2014
    USA
    Mine had the same issue. Don't see me going back to that tire unless there quality control improves.
    Seemed to me there was less meat on one side of the tire than the other from day one. Over time you will see what you have in the picture
    I had 8K on mine but could have went longer
    Active Member SpyderF3's Avatar
    Nov 2016
    Hummelstown.Pa.
    Maybe its due to road crown, I see the same thing on the 300 tire on my bike.
    Active Member Maurice Leduc's Avatar
    Jan 2015
    Brownsburg Chatham Québec Canada & Fort Pierce FL
    Mi brother ad the same probleme whith his rear Arachnid tire an the Riendeau BRP Dealer ou instaled it said it's cause to bad inlinement. An they install a new Kenda an did not charge for it.
    Maurice RV Full Timer
    Spyder RT SM6 2014 Blanc Pearl.
    Sep 2014
    New Jersey
    Default weird tire wear
    thanks for your input, definitely not going with the arachid tire again either the kenda or a car tir seeing how some of the riders out there have had good things to say about them, will let you guy know how it turns out
    2020 RT
    XK Glow light
    Default KENDA
    Quote Originally Posted by GS1 View Post
    KENDA - really, I don't know anyone here who would recommend the Crapenda for a rear tire ........... .... Mike
    Mar 2012
    NJ
    KENDA - really, I don't know anyone here who would recommend the Crapenda for a rear tire ........... .... Mike [emoji106]
    I like my Kenda...As do a handful of us.
    Sent from my Nexus 6 using Tapatalk
    Sep 2014
    New Jersey
    ok then what tire would you recommend
    2020 RT
    XK Glow light
    May 2013
    Apex, N.C.
    I installed a kumo on my 2014 RT when my original Kenda wore out at about 7,500 miles. I just turned 20k and have plenty of tread left. The kumo also only cost around 80-85 bucks at Discount tire.
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    Quote Originally Posted by DrewNJ View Post
    I got 18K on my first rear tire, and 12+ on my second, replaced because I got a nail in it, advised to not plug. Next Kendra I forget how many miles, Replaced my front tires at 32K, since having squared away aligned the OEM have around 24+ still look good. Road temps in So Cal aren't that bad on the tires I guess.
    I use Kenda because my dealer will not install any other. And, I am mechanically challenged.
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Yokohama s Drive that is a great Tire
    Vermont
    I am running the General Altimax RT 43 on the rear, replaced the Kenda @ 5,824 it was not safe . It was down to the ware bars. I have 10,176 miles on the General, size: 215/60 R15. I have a 2014RTS-SE6. Here is a picture: New Rear General ALtimax RT 43 Tire 001.jpg I am running @ 26 psi. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by jtoro1 View Post
    Harrington, Australia
    Yeah, we all have different drivers, AK. It's a pity Can Am doesn't see the value in letting their dealers replace tyres with car tyres though. I know they have an agreement with Kenda, but there is NO question that I would take my F3 to my local dealer to have the tyre replaced, rather than do it myself, if the option were available.
    HeliBars Handlebars
    Kenda Kanine rear.
    Default TIRE
    Kenda's are fine for the front ..... For the rear they wear out very early .... Get a General Altimax RT43 in 215/60-15 or Michelin Primacy or Pirelli 4 season Plus ...... Mike
    Nov 2013
    Oro Valley Arizona
    ​I have always used Kenda's and think there great Mike. Here they cost $180 and that includes free install.
    The new compound is almost doubling the mileage and still is soft enough to have excellent traction when wet. Not so the car tires! I personally feel they are a safer tire and much easier to find. Most Spyder dealers stock them. Come April I will celebrate 66 years of riding Motorcycles. Only added this to let you know I am not a "newbie" when it comes to motorcycle tires. There is a whole lot more to motorcycle tires than mileage. I hope everyone realizes this for there own safety.
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Quote Originally Posted by jaherbst View Post
    ​Jack
    I don't know whose posts you have been reading, Jack, but they couldn't have been Mikes or Peters if you think they suggest that you replace the Kendas with car tyres simply for mileage considerations. The arguments they present are ALWAYS about rider safety first.
    HeliBars Handlebars
    Kenda Kanine rear.
    Default JACK IN ARIZONA
    ....Pete, it's all about the messenger for some folks here .....ie. if Lamont made the same statement the PRAISE would have been Instantaneous & Unanimous ....... Mike
    Sep 2014
    USA
    ​Jack
    Except for the 2014 rear tires with softer compound (I got 8,900 miles), all the other OEM Kenda's have given me 15K plus on mileage.
    Sep 2014
    New Jersey
    Default got the new tire
    put on the yoko s drive tire today short ride to work there is a difference will update later as I have a few longer rides planned for the rest of the week
    2020 RT
    XK Glow light
    Very Active Member otter28169's Avatar
    Aug 2012
    East Pharsalia, NY
    The wet traction of that tire is amazing an I got 9000 miles out of it. But then again, I ride too fast an we all know what that does to rear tires.
    Just sayin'............
    Three in the garage, and I think I can fit at least one more in.....and then we will have to build another garage.
    The roads in NY are so bad that I am glad we bought a Ryker Rally
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default How would you know... ????
    ​Jack
    How can you make a judgement call like this if you ALWAYS have used kenda tires, and have NEVER tried a car tire?
    Try them, after you will be able to talk. Otherwise, you just express an opinion, without any value..... sorry to have to say it as directly, but, please stop talking without knowing the facts.... and this is MY opinion.
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
