Page 1 of 3 123 LastLast
Results 1 to 25 of 71
    Member donmorris's Avatar
    Ceciltucky MD
    Question Motorcycle campers and the RT
    Does anyone on here pull a Roll a Home, Bunkhouse, Time Out, or similar trailer behind their RT?
    Looking at the RT Limited, specs say a ridiculously low tow weight 400 lbs. Yes, I know, lawyers and law suits. But this is most probably not reality.
    Currently, tow a fully loaded Roll a Home behind my GL 1800, no problems, and it says not to tow at all. For the most part don't even know its there.
    But, I would like someone who actually tows to give some feedback.
    Don
    Sep 2012
    Junction City, KS, USA
    I used to have a Leesure-Lite camper that was only 200# empty. So you can find trailers that are under the prescribed weight limits.
    You just have to figure out where to look, and what is it, that you really need to take along with you!
    A lot of the time, it's not about the "going": it's about the stopping!
    May 2013
    Hackensack, MN.
    Default Camping Trailer
    Pulled a camping trailer for 2 summers. 300 plus #, loaded I am shure over 400#.Pulled up and down hills in Duluth two up with my 995. No problems.
    Default TOWING TRAILERS
    I'm sure all of those trailers have been towed and a bunch more not mentioned ..... IMHO it's not how MUCH the Spyder can tow ( I actually pulled my Toyt Echo 3100 lbs about 25 ft when I testing a home made hitch with my Syder ) It's how much you can SAFELY STOP WITH , is the real issue. I'm 69 years old and have moved a trailer that weighed 1600lbs by hand. If you could fix up a workable electric brake for the trailer ...... 600 lb would be doable ........ Mike
    Feb 2012
    Spring City,Utah
    To me the important question would be not the total weight but the tongue weight. BRP specifies a tongue weight of 40#.Since the hitch is mounted to the suspension and not the frame you want to stay at or below that weight. You can compensate for increased overall weight by riding slower and braking sooner.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Ceciltucky MD
    I had brakes installed on the camper when I purchased it.
    Works great.
    Ceciltucky MD
    I have a scale and load trailer now so that the tongue weight never goes over 35 lbs.
    40 should be doable..
    May 2013
    Hackensack, MN.
    If I got another one I would put brakes on it. Yes ,need to watch weight on Hitch.
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    I've been trying to figure out what this thing weighs - all thin wood and fiberglass so it should be lightweight (Thread police! I surrender!)
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Mar 2012
    Beaverton, Oregon
    WE use a Aspen Sentry. Queen bed and a 5x5 ft. dressing area. This model is a "basement " model so it has more storage space. I do not pay as much attention to weight as I do to load distribution so the tongue weight doesn't exceed 40 lbs and at least 10% of weight..
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Sep 2016
    US. ohio n/e
    I pulled 500 lbs 1600 miles ...i only have a hand brake because of missing right leg....bike did grt...like everyone saying. ..its the stopping. ..freeway speeds is slow response...but city speeds is still very good....im looking at a electric over hydraulic system for trailer brakes..for. New trailer camper...my tongue weight was under 30lbs
    Sent from my LGLS675 using Tapatalk
    Sep 2016
    US. ohio n/e
    http://cloud.tapatalk.com/s/589901be...12_173633.jpg?
    Jul 2013
    Vestaburg Michigan
    Pulled a Time out trailer 20, thousand miles . No issues, used trailer mode and slowed down for intersections. Had extra gear and small A/C on top.
    Ceciltucky MD
    Default Thanks to all
    You've all pretty well verified what I was thinking.
    Now to get the better half to agree, Oh well that's another mountain to climb.
    Default weight
    Quote Originally Posted by OverHillAndDale View Post
    You could try 3 bathroom scales - not exactly accurate , but much better than SWAG ....... PS looking at where the AXEL is ..... I would definitely get a reading on the TONGUE weight when using with a Spyder !!!!......... Mike
    Jun 2010
    Las Vegas
    Quote Originally Posted by donmorris View Post
    I'd be willing to bet that she would prefer reservations at a hotel over a trailer.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    I've pulled my 'tent on a trailer' several thousand miles. It weighs on the order of 400 to 450 lbs. As others have said, stopping is primary concern. I can tell when it's attached when it comes to stopping. What others haven't mentioned, and it's a big difference from your 1800, is power at interstate speeds. At 70+ pulling 400# you will not have the reserve torque to pass a semi like you had with the 1800. Gas mileage will take a hit, especially if the trailer isn't aerodynamic. If you're thinking about pulling 500# plus, and you get into a headwind going uphill, and want to travel 70+, you very well may get frustrated. Plan to do a lot of driving in 5th gear, and maybe even 4th. Cruising on the level with no headwind you'll do fine in 6th.
    Sep 2014
    United States
    This is a kit from Chesepeake Wooden Boats - here's a link. They ship wood parts and instructions, you assemble. You also provide a trailer to put it on.
    http://tinyhousetalk.com/gorgeous-te...e-light-craft/
    https://youtu.be/RnWOynlBHfg
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Thanks!
    I'd have to put it together?!?
    I can smell a "Disaster at Sea" brewing...
    Default MUCH LIGHTER STUFF
    ..Google .... " Corfam " .... This product is incredible as far as being extremely strong, waterproof, and very, very lightweight. Plus it's very cost effect....... Mike
    Oct 2013
    Wood Village OR
    Default Campers and RT
    We have a Aspen knock-off and completely loaded it weighs 420 lbs. I have not had any trouble stopping. I've logged over 40 thousand miles pulling it first with the 998 and now the 1300. My wife and I look like a couple gypsy's going down the highway. We do try very hard to stay off the interstates as I like to enjoy the ride and there is nothing to enjoy about the Freeways.
    Camping up on the Crest 4-19 001.jpg i phone photos 118.jpg i phone photos 030.jpg
    2014 RTL , Black Currant
    Jul 2015
    Dorr, michigan
    I tow a bunkhouse with a 2014 RT 1330. I have towed all over from home in Michigan to and through Colorado, Utah, and Nova Scotia. I have a little over 18,000 miles in two riding seasons and over 10,000 was towing that trailer.
    2020 RT Limited , Petrol Blue
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    We go to the beach, she tows the camper and I tow the Tag-Along. Works for us. We had a Combi-Camp, now have a Roll-A-Home camper, have yet to tow the new one with a Spyder. When we went to the beach this last year 45° and rain was predicted for half the time we were going to be there, and it did, so we took the cage. Still had a good time.
    I will let others talk about weight and such. We were a bit heavy with the Combi-Camp but didn't actually weigh it until we sold it.
    Never ever believe the advertised weights of any RV trailer.
    There is a great resource for general motorcycle camping over at http://www.motocampers.com/
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
