Results 1 to 14 of 14
    Feb 2016
    Kansas City
    Default Antifreeze leak?
    My wife has a 14 RS-S and while sitting over the winter i noticed that there is a small drip of possibly antifreeze dripping down from the front right of the bike. I have never had much of the bike apart. I am fairly handy with tools. I'm not afraid of doing shim under bucket valve adjustments on my bike. I really haven't looked into this bike much as far as where everything is. Is there any guidance from you all on what might be causing this. Drip is right behind the back side of front tire on right side and its coming off the platic pan or bottom of frunk. Thanks in advance for any advice.
    Feb 2016
    Kansas City
    After doing about 5 minutes of research looks like it might be coming from the radiator drain plug. That is right over where im seeing the drip. Looks like the side panel and lower black panel are pretty easy to remove. Next question is whether or not this is something common and to look where first. I highly doubt the radiator is bad. Is there a history of loose hoses or anything?
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi corpssgt,
    Re: Drip is right behind the back side of front tire on right side and its coming off the platic pan or bottom of frunk.
    I had the same thing with my '08 last year. It turned out to be a hair-line crack ( not visible to the naked eye ) in the plastic coolant bottle. This hair-line crack was vertical & on the rear face of the coolant bottle. The only option was to replace the coolant bottle.
    When we squeezed the coolant bottle we could see liquid coming out of it. It was only in the upper 3rd portion of the coolant bottle so once the coolant level got below the crack, no more coolant would leak out.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Default Let's see....
    The three most common leaks are....the cracked tank (little less common today) the radiator hose clamp (the only adjustable one that needs to be tightened) and the water pump seal. where the drip is forming is seldom the source of the leak. You do need to pull a few panels and give it a good once over to find the spot. I would suspect the hose clamp....
    ​2012 RS sm5
    Feb 2016
    Kansas City
    Well looks like a weekend project. Thanks for the replies. I also used the search function that I should have used first and found some info. I guess I'll just keep everyone posted if its something new.
    Default CLAMP
    Chewey ...... CAN an Otecker (?) clamp be ADJUSTED / TIGHTENED ...... I didn't think ...... However there are a few high quality screw clamps that can re-place those ............ Mike
    Default Your right....
    The okiter (sp) clamps are one time use and size specific...but for some reason there is one hose clamp on the radiator that is a worm drive and I think assembly folks forget to tighten it and after a spell it leaks. Quick turn and your done...I do like the overlap worm drive clamps myself...
    ​2012 RS sm5
    Oct 2013
    rome new york
    yep to Gene. Have a 13 rs and had clamp leak
    Feb 2016
    Kansas City
    How would someone go about getting to this adjustable hose clamp? From what ive seen looking at pictures only im guessing this clamp joins the two radiators near the top were it then heads back toward the engine. Can you get to it from below? Will I need to remove the Frunk? Thanks again.
    Active Member garageguy's Avatar
    Jan 2015
    Flint Hill VA
    Default Leaking hose clamps
    Just got my wifes 2015 STL back from the dealer. Had a good sized coolant leak right side. They found FOUR of those crimp on hose clamps leaking including up top where the airbox/manifold needed to be removed. they replaced all the crimp ons with adjustable hose clamps BEST warranty (an oxymoron ) would not cover since they exclude hoses. This is obviously not a wear and tear issue folks.
    Northern Kalifornia
    Default Yep, me too..........
    A small leak last winter and much larger leak this winter. Took it to the dealer and the tech replaced two of BRP's finest crappy parts. That dam company should be thoroughly ashamed, but they're not. A 30k machine assembled with $30 worth of crappy parts, costing their customers thousands to replace/repair the defects, and all the while not allowing warranty to cover the costs, or even part of the costs. Cheap parts and shoddy assembly. That's BRP for you. No wonder they have the lowest rating for durability/reliability.
    May 2014
    Beaverton, Oregon
    Hi 2dogs,
    Re: A small leak last winter and much larger leak this winter. Took it to the dealer and the tech replaced two of BRP's finest crappy parts. That dam company should be thoroughly ashamed, but they're not. A 30k machine assembled with $30 worth of crappy parts, costing their customers thousands to replace/repair the defects, and all the while not allowing warranty to cover the costs, or even part of the costs. Cheap parts and shoddy assembly. That's BRP for you. No wonder they have the lowest rating for durability/reliability.
    I could not agree more.
    However, in defense of Oetiker, their clamps were never designed for these applications.
    Blame BRP only for this: dam company should be thoroughly ashamed
    Jerry Baumchen
    2008 GS SE-5
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Default Hose clamp access
    Quote Originally Posted by corpssgt View Post
    corpssgt...
    I just went thru a similar experience on my ST...and tightening the one worm clamp I was able to get to seems to have fixed the issue...
    http://www.spyderlovers.com/forums/s...de-panel-on-ST
    I did have the dealer check and they replaced one oetiker clamp and ran a pressure test...no issue found...
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    2016 ST-S , Steel Black Metallic
    Jul 2016
    Jackson Michigan
    I had this same exact problem last winter on my 2014 RSS. All I had to do was tighten a hose clamp up and it fixed the problem. Check the easy stuff first.
