Results 1 to 25 of 25
    Dec 2016
    Somewhere USA
    Default New Owner and a question
    Hello all! I picked up a new 2016 F3s Special SE6 a week ago after much brain twisting. I chose the Spyder because I felt the feeling of unlimited adventure when I test rode one months ago, studied and watched a gazillion YouTube videos. I had the dealer install floorboards, driver backrest and heated grips. I purchased a top case rack and placed my Givi Monokey V56 to it. Afterword's I purchased the fog lights and installed them myself but wished the dealer did that as well. Installation was NOT as easy as the online instructions suggest. I also purchased and installed a MADSTAD 18" windscreen. I can not comment on the windscreen since I cant as yet ride it....snow. I'll give my thoughts on MADSTAD when I have experience to detail. Installation of the MADSTAD took 2 hours and seems very high quality. Friends came over and everyone agreed the maneuverability of it was awesome.
    Now my question. I noticed that the brake lever is VERY high. I rode the bike home from the dealer and had to pick up my foot to press the brake lever. Can I move the floor board forward a bit which will by the restrictive nature of the brake rod lower the pedal? Are there aftermarket "kits" that offer a lower pedal? Thanks for any feedback.
    Jun 2013
    queens ny
    your question will have to be answered by someone else, but i just want to say congrats, and many happy miles and smiles
    NO BIKE AT THIS TIME
    Default Welcome. ..
    congrats on the new ryde.. you should have some adjustment, check your manual. welcome
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default Congratulations on your new RYDE...
    ... but I don't have an answer - trust me, someone on here knows what you need an answer to....
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Vermont
    I do not have an answer , I am sure someone on this site will ride in( ) and have a answer for you.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member Gsebring's Avatar
    Houston
    Default Brake pedal
    The F-3 has the u-fit system on it. Can move the the boards and brake pedal with a kit. I moved mine to the #5 position and the brake pedal remains high. I have not seen a adjustable brake rod to lower it. Somebody may want to design one for that purpose.
    Happy trails!
    Mar 2013
    Oz
    Yes You Can
    saw it it on here some time ago, told our dealer, now he does it for many.
    At at one end of the brake linkage rod is a little hole - just drill another hole a little distance away and it lowers the brake pedal nicely - much better and safer.
    As noted, it was posted here with pics. If no one chips in I shall ask my husband for a slightly more technical explanation for you.
    See post #7.
    Active Member 9tda1dr's Avatar
    Nov 2016
    Ball Ground, Georgia
    Congratulations! You will [emoji7] love it!
    Sent from my iPhone using Tapatalk Pro
    2015 F3S SE6
    2015 F3S SE6 , CanAm Red
    Active Member LateLifeCrisis's Avatar
    Maryland
    Default Can't help you with the brake situation, but........
    I can't help you with the brake problem, but just wanted to say........I AM SOOOO JEALOUS!!
    And seriously - ENJOY!
    He's on his RT She's on her F3
    And the Keys to a Happy Marriage: Separate
    Bathrooms, Individual Remote TV Clickers, and
    His and Her Spyders.
    "If there are no dogs in heaven, then when I die,
    I want to go where they went." ~ ~ Will Rogers
    "Never in the field of human conflict was so much owed by so many to so few."
    ~ ~ Winston Churchill in his tribute to the RAF.
    "I'd like to know why well-educated idiots keep apologizing for lazy and complaining
    people who think the world owes them a living." ~ ~ John Wayne
    GOS 3799
    Dec 2016
    Somewhere USA
    Quote Originally Posted by loisk View Post
    Yes You Can
    Thank you. Tomorrow I'll check out what you said. Maybe I'll call my dealer and see if they have a fix as well.
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    There are 3 options, drilling the bracket the rod links to shown in this thread:
    http://www.spyderlovers.com/forums/s...ht=brake+drill
    or drilling the rod itself as in this thread:
    The ppic is no longer there but the idea is to drill a hole through the bracket at the end of rod where I've put the red dot here:
    That effectively shortens the length which will lower the pedal.
    Risks are that you will weaken the strength of the bracket and make it more prone to failure. AFAIK a few have done this but I've not seen any evidence of failures.
    3rd option is to cut the rod, chop a chunk out and re-weld it up. A few have done this with no issues AFAIK (depending on quality of welding of course).
    JC Thorne has done this on his and a few others I seem to remember.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Sep 2012
    Junction City, KS, USA
    I'm glad others have answered your questions since I can only tell you &
    PrairieSpyder (Patti)
    Invalid Emails
    May 2016
    Columbia,tn
    Hope you have gotten your answer. Just wanted to say Congrats on the new ride. Ride safe. Be Happy. Enjoy Life
    Active Member SpyderF3's Avatar
    Nov 2016
    Hummelstown.Pa.
    You could get a pair of these in the proper size and a piece of threaded rod cut to length
    http://www.homedepot.com/catalog/pro...e841e_1000.jpg
    Dec 2016
    Somewhere USA
    Quote Originally Posted by monkeyboymorton View Post
    Thanks for the feedback. I'm going to look into this today as well as call my dealer. Maybe there is a quick dealer fix as well. I'm a bit nervous about messing with the brake lever because it the ONLY brake I have. I'll keep everyone informed.
    Invalid Emails murphybrown's Avatar
    May 2010
    Chelan, WA .. the dry side!!
    Default Welcome, Wecome & Welcome
    My answer to the brake issue. I also "struggled" at first 'finding' the brake pedal...But after about 500 miles of cautious ryding my foot now can find brake with ease. I know others have 'adjusted' height. For me just had to teach this "old dog" a new way to find necessary brake pedal. You will LOVE your F3...sounds like you are doing a great job on farkling.
    My Motto Is:
    Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh, crap, SHE'S awake!"
    Red Stallion: 2016 F3t SE6 (from Pitbull PowerSports/ Springfield, MO)
    White Knight: 2014 RTS SE6 and matching 622 trailer (from Pitbull
    Ms Spydee: 2010 RT SE5
    Dec 2016
    Somewhere USA
    Default Done!
    I went out just now and removed the brake rod. I drilled a 5/16 hole 1/2" behind the front hole on the forward end. I had to file 1/8" off the break lever to make the fit loose and not snug, it has the same play as before. This lowered the break pad 1" making it MUCH more accessible in emergency breaking. Tools needed...5/16 drill bit, 5mm allen key, 10mm socket, 16mm wrench (for break axel bolt) and a file. Another alternative would be to dremel out the safety notch located inside the break pad and drill out a hole installing a bolt 1/2" forward of the current bolt, this moves the floor board 1/2" forward though. The other way would be to cut the break rod, remove 1/2" and have it welded back together. Hope my pictures show the handiwork, its my first time loading pictures to this website so I'm hoping it goes smooth. I think overall I would have cut the pipe and had it welded back together if I was to do it over again.....just my thoughts.
    Dec 2016
    Somewhere USA
    Default A picture of my Beast
    Active Member Slagiatt's Avatar
    Jan 2013
    NW Indianapolis
    Default Top Case
    What type of Luggage Rack is it that you're using for your top case? Brand? URL?
    Thanks!
    F3S Steel Black Metallic
    Former owner of '12 RT-S SE-5 and '09 GS SM5
    Dec 2016
    Somewhere USA
    Default Givi Monokey V56
    Quote Originally Posted by Slagiatt View Post
    Thanks!
    Givi Monokey V56 Carbon Fiber (fake CF) bolted directly to a solid steel luggage rack sold by Value Accessories. I decided NOT to go with the universal Givi mounting plate because it mounted too high. I kept the V56 from a previous bike and it looks great on my F3s.
    Please note that the luggage rack is HEAVY (around 30lbs) but it holds per instructions 40lbs. I think it holds 100lbs from its solid structure. Its bolts on super EASY!
    http://store.valueaccessories.net/Ca...ggageRack.aspx
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    Quote Originally Posted by Road-Kill View Post
    Congrats on the new bike! Does the rack make it difficult to remove the seat?
    2016 F3L , Big Bike Parts Black
    Dec 2016
    Somewhere USA
    [QUOTE=papanorm;1221459]Congrats on the new bike! Does the rack make it difficult to remove the seat?
    It does not. Not even slightly.
    Sep 2015
    UK
    Thanks for sharing your handywork on the pedal, pictures really help see the difference. I think that's the first one I've seen where someone has drilled the pedal bracket. Looks to have done the job just as well.
    This does seem to become more of an issue wth the floorboards as they take your foot further from the pedal. Not so much of an issue if you're still using the pegs.
    Jan 2013
    NW Indianapolis
    Default THANKS!
    Really appreciate the feedback and the link!
    Richard
