Looking for replacement
So Id like to find a BRP 4pin square jumper cord that extends from the module to the trailer. Mine has some damage, still works, im just not happy with it. image.jpg The part seems to only come with the ST hitch kit & i can build my own yes, but want the rubber caps, with tether molded in, that are on either end that is the part i can not get.
image.jpg The plug ends also have a square blank to place the cap when not in use.
fyi barcode numbers on it are 199C2010515083000A
Other numbers on the cord are:
BRP710 003 199
REV:2 01/05/15
Hope this will help
A whole cord would be great, but willing to use just the ends, if in good shape & with the caps attached.
Thsnks in advance
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
If possible
When all said done, if you end up with an extra cap, even if cut off, I'd be interested in it. I'd like to be able to cap the trailer end when it's being stored.
Thanks in advance and good luck finding your cable
2014 RT-S Pearl White
http://www.autozone.com/trailer-hitc...set/276150_0_0
I came up with a blank when I searched the vendor I bough mine through in 2014 -- but searching the part number I bought came up with the above link for autozone.
Good luck!
Bob
Amazon has it if you type in 4 pin suare connector . you are lookin for this plug Hopkins 11147975 4 Pole Square Set
https://www.amazon.com/Hopkins-11147...ler++connector
BRP710 003 199 is the part number for your cord as you posted.
Brent
just use an old spare connector end, it will serve the same purpose. (trim off useless wires)
Cruzr Joe
Thanks Joe
Originally Posted by Cruzr Joe
Brent
Cruzr Joe
Good idea, found one online for $2.50
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
