Tire pressure in the Rear Kuhmo tire
I took my Rt out last night after a tire change to the Kuhmo tire. I hit a couple corners a little hard and the nanny kicked in for slippage. I currently have 25PSI in the tire. Is there an ideal pressure to stop the slippage. I do not need any debate on which tire is the best and which one I should have went with. Just an answer to the question of what tire pressure is ideal for the RT with 2 up normally.
PLAY
EVERY INDIVIDUAL IS DIFFERENT, AND EVERY RIDING CONDITION IS AS WELL...
JUST PLAY WITH YOU RIDE BY GOING EITHER UP OR DOWN ON THE PSI TO FIND THE BEST POSSIBLE CONDITION FOR YOURSELF....
HOWEVER, WITH THAT SAID, YOUR STATEMENT THAT YOU HIT A CORNER 'A LITTLE HARD' WOULD INDICATE THAT THIS IS THE REASON FOR SLIPPAGE.... KEEP IN MIND - THERE'S NOT MUCH WEIGHT BACK THERE...
RIDE SAFELY AND ENJOY...
DAN P
SPYD3R
What model Spyder do you have? I have an RT Limited and recently installed a Kuhmo on mine and couldn't be happier. It solidified the handling and I haven't had is slide yet. I too normally ride two up, and my wife likes it better also. I normally 26 psi and it appears I am getting even wear across the face of the tread. Sorry to hear you are having trouble.
David
TIRE PSI
I sort of agree with Mike...
But I haven't been able to gather up the courage to drop any lower than 24 psi yet.
At 11,000 miles: it's still looking pretty darn good.
Perhaps this Spring is when I'll drop it a couple of more psi...
Bob, just for a discussion ..... what do you think MIGHT happen if you went to 21 psi ? ......... Mike
Congrats on the new tire
Looking forward to some warmer days ahead and hopefully when the gravel gets cleared off the roads a bit. Play with the pressures and see what suits you and your riding style best.
There is no wrong pressure for these car tires IMHO between 20 and 30 psi you will still be rolling and enjoying your ride. Look to the air pressure guide for your air shock as well to explore your options and find out what is "BEST" FOR YOU! We ride mostly one up on Kumhos at 27 psi. (right now they're in the garage at 24-25 psi at 50F)
I know that brand new mc tires can be a little squirrelly until they get a little wear on them. Could that be the case hear?
Mark in GA
2014 Cognac Spyder RT Limited - SOLD
2014 Cognac RT-622 Trailer - SOLD
Tire pressure in the rear Kuhmo tire
New tire are slippery......
.....until you "scrub it" enough..... proven so far with a 3 kumho and 1 proxie4.... also used the kumho down to 20 lbs single with n.p. Went back up to 22 after seeing that 1/4" of the shoulder started to be scrubbed when riding hard. ( close to the limit) at 20. At 22 stayed the same.
Richard
* 2012 RS SE5 (hers)
* 2013 ST SM5 (mine)
Daughter RSS SE5 2014
Son in law RSS SM5 2013
P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
2 sets of Kumho 175/55R15 front tires
1 set of Hankook V4
1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
drive it around a bit and see if it gets any better for BITE.. Then try PSI adjustments.
Still a bit cool outside yet too
My $.02 and worth every penny maybe?
As you say you just had the tire replaced, the slippage may be due to the tire needing a couple of hundred miles or less to scrub the tread surface of mold release and roughen it a bit to obtain maximum traction. And as others advise, a lower pressure may work better depending on the load and road surface. Have fun!
TIRE PRESSURE
I find this interesting ....... I have more than 75,000 miles on various CAR tires - Kumho, Michelin, Falken, Toyo and at 20 - 21 psi ( did some testing at LESS ) and never experienced - sidewall SCRUBBING ....... There are folks here who have ridden with me and I think they would agree I ride at 9/10 ths a lot ......... Mike
I just got back after about a 75 mile ride. The tire did not slip today and I even got caught in the rain with no slippage. Talking about pucker factor when you are trying a new tire and then it decided to rain on you.
22 psi? I think that I could talk my chicken-**** self into that...
I've dropped mine to 22 on the F3-L with my 310lbs on it, Bob. I "believe" it is a little more stable than it was at 24, but my seat-of-the-pants impressions are not usually worth a damn
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
I had a little bit of a rear "step out" yesterday, rounding a 50mph corner at 50mph on my Kuhmo KU22 205/55 that now has around 400 miles on it. I rode on, and was tossing over in my mind whether it was nanny, tyre pressures etc etc, and I thought "why am I guessing"?
So I rode back and had a look at the corner, and sure enough, right on the rear tyre line was a recent 18"x18" hot mix patch that I hadn't seen on my first pass. It was combined with a hundred degree day to make it pretty slippery. So I rode back through the corner and the back slipped a little again. If I hadn't gone back I would probably STILL be guessing just what caused the step out.
HeliBars Handlebars
Kenda Kanine rear.
RS-S 4 lbs under spec with nitrogen.
If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
Sea Doo GTI-SE 90 Jet Ski!!
HeliBars Handlebars
Kenda Kanine rear.
Nanny kicked in for slippage? I haven't come across that yet, and I power slide as often as possible!?!
Sent from my SAMSUNG-SM-G890A using Tapatalk
Richard
1 set of Hankook V4
NOT SCRUBBING
......Not sidewall, just the first 1/4" on the tread rounding towards the sidewall.... I didn't mean the tire was lying on its side..... 😄
Actually neither did I ..... With a Spyder I don't think that's even possible ..... But, you say that went away after adding 2 lbs of pressure!........... Generally speaking the Car tires we are using ( not Kenda or Arachnid's ) have a load capacity between 1450 and 1600 lbs ..... PER TIRE ..... even the RT with a full load of 400 lbs. has possibly 625 lbs load on the rear tire ..... I find it extremely hard to believe 2 lbs can do what you are saying occurred .... Mike
I Agree....
Richard
1 set of Hankook V4
