Results 1 to 12 of 12
    Nov 2016
    Cass Lake MN 56633
    Default Thinking of Spring
    Here in Cass Lake, MN -32 deg F
    Thinking of SPRING
    Tony
    Very Active Member bronzeflex42's Avatar
    Sep 2014
    Sandersville, GA
    Default Ride Time
    It is almost like spring here in Gawga!! Instead of lions, tigers, and bears; it's blue sky, bright sunshine, and a high of 72 degrees oh my!!
    2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
    Feb 2012
    Spring City,Utah
    Yes PMS is hitting hard here in Central Utah. Cold, raining or snowing for the last 4 days. Lots of ice around. There are only 64 days till Spring
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default Sooo.....
    If 32° is freezing have you reached the double freeze... Will spit freeze before it hits the ground....???
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Spring can NOT come soon enough! Below zero much of the week....not quite as cold as Tony in Cass Lake, MN.
    PMS is real and it's tough to look at those bikes in the garage just waiting to get out!
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    May 2016
    Winnipeg, Manitoba, CANADA
    Default Come on Spring ... please hurry!
    Quote Originally Posted by tony63126 View Post
    Here in Cass Lake, MN -32 deg F Thinking of SPRING Tony
    Just north of you in Winnipeg, MB ... - 29 Celsius with a 70 kmh wind. Brutal!
    And, we are also thinking of spring. It's beautiful with the new snow we got last night. The deep freeze has broken and we are headed for high twenties to low thirties. ABOVE even.
    Vermont
    Today, we had 41 degrees, cloudy, and snow still on ground.
    Next week they forecast 30's to 40's and rain, sleet/freezing rain.
    I am having spyder withdrawals. Only 2 months until spring! Hurry Up Spring!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    May 2016
    Default Spring is around the corner
    Here in Cass Lake, MN -32 deg F Thinking of SPRINGTony
    Just up the road from you in Winnipeg we're also counting the days. It's been + 2 Celsius the past week and spring is just around the corner!
