Results 1 to 24 of 24
    May 2015
    Arlington, WA
    Default Snow tires on a Spyder? Why not?
    Hi folks,
    Posted a similar question on facebook but thought I might get more constructive replies here.
    People have asked if Spyders can be ridden in the snow and the general response seems that the tires don't have enough traction. But since our tires are basically automotive sizes, what's wrong with putting snow tires on a Spyder? Studdless or studded?
    I live in Seattle so we don't see much snow but I would love to take the Spyder east of the mountains. I do ride year round BTW.
    I did consider the possibility of snow gumming up the belt but I think as long as much snow isn't getting kicked up from the ground, it should be manageable... ??
    2015 Spyder F3-S SM6
    GriffonT, I've run 'all-weather M&S' rated tires (non-studded) on my 2013 RT Ltd AND ridden some significant distance in snow (some of what little we have Down Under) on effectively 'un-cleared roads' without any problems!!
    So if you keep to the same sort of tire sizes that are known to work, make sure the more aggressive tread isn't going to catch on anything underneath, & keep your control inputs smooth & gentle to avoid wheelspin or traction loss when attempting sudden direction or speed changes, you should be fine!!
    Others besides myself have also managed OK ryding in the snow, there are even vids posted on youtube of this occurring; altho there are also some few who've demonstrated that it is pretty easy to wake the Nanny up & thereby trigger limp mode thru those aforementioned 'control inputs' to avoid (ie, the aggressive stuff!) But I feel sure that if you try to avoid bringing that sort of thing upon yourself by ryding smoothly & slowly with gentle control inputs, & the snow isn't too deep or icy, then you shouldn't have too much trouble.
    I seem to recall that SethO gave studded tires a try...
    I don't remember how it worked for him; you might want to PM him, to find out.
    Aug 2008
    MA & NH
    Any salt use in the area ? Very nasty stuff, I always come off the road before that appears. Good luck.
    So do I.
    Quote Originally Posted by Saluda View Post
    Any salt use in the area ?.....
    We don't hafta worry about that salt stuff too much in our snow fields here - just about everywhere that we are likely to see snow much at all is either in a National Park or a Conservation Area, and salt is definitely NOT PERMITTED!!
    They can use grit on the roads, but not salt - that might hurt the rare roadside weeds or the even rarer pygmy possums, corroboree frogs, etc!
    Default You can....
    Mostly it is a maintenace thing being so low to the ground. salt, chemicals and sand do make for many problems if not cleaned off right after a ryde. Pure snow would be fine but one still wonders how well things under there hold up if packed with snow....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mar 2016
    Willis, Michigan
    Studded tires are illegal in MI, and they were also banned in NY when I still lived there (Bob, have they repealed that?). It seems utterly insane to render us helpless, but their excuse is that studs cause excessive wear and tear on the pavement.
    2015 Sypder RT-S SE6
    2016 Polaris Sportsman 570 ATV
    2003 F250 SuperDuty
    American Saddlebred Horses
    As far as I know: they're legal in New York... from Mid-October through Mid-April.
    But since I haven't used them in years: my information may be out of date.
    Oct 2010
    Wisconsin Rapids
    SethO used a studded tire in MN. He said he could drive through 6 inches of the white stuff. Also said they are illegal, but he is disabled vet. They didn't give him any trouble. That's what he told me.
    Default SNOW TIRES
    Hey girl how you doing ...... IMHO this is silly, but think about these issues ..... Tire size, a 225/50-15 Snow tire is quite a bit larger than that size in an ALL-SEASON tire so it may not fit ...... I would PM Seth-O and find out EXACTLY what He used /did etc......... The rubber compounds they use today in GENUINE SNOW TIRES are very different than other tires ...... that's why they DON'T GIVE WEAR WARRANTIES on them ...... and I have seen video's of Spyders in the snow .... they aren't going over 20 mph and none have slammed on their BRAKES ...... things to think about ......... please don't try this, I like you ..................... Mike
    Aug 2012
    CO
    I've ridden with the stock tires over patches of snow / slush - keep the inputs smooth and the Spyder gets through it fine as long as it's not too slick or deep. Snow tires would greatly enhance traction. Mostly the folks who don't ride in the snow don't want the added cleaning/maintenance afterwards or like me, don't have a second set of wheels (or the lift/tools) to swap in and out each season.
    JLohPhotos
    2008 GS , Millennium Yellow
    I spoke in detail about studs and snow tires in the most two recent threads on the subject. I am against their use.
    Sep 2016
    Alma,Arkansas
    Default Snow travel with a Spyder
    I was on a site the other day and noticed snow chains for bikes. Anyone use them?
    Good Luck
    Mar 2016
    Willis, Michigan
    Yup, you're right. According to legalbeagle.com:
    Technically speaking, it is unlawful to operate a vehicle outfitted with tires that have metal devices extending from the tire tread in New York. It is, however, legal to operate vehicles equipped with studded tires that meet certain tread specifications, but you can only drive them between October 15 and May 1.
    The law against studded tires does not apply to tires outfitted with metal studs that have a diameter less than three-eighths of an inch and a length less than three thirty-seconds of an inch. Furthermore, your studded tires cannot have a contact area more than three-fourths of one percent of the total surface area of the tire. You can determine the surface area of your tire by taking the circumference of the edge of the tread and multiplying it by the width of the tread.
    2003 F250 SuperDuty
    I think that they did that in order to keep folks from filling their tires with sheet metal screws, and then scattering them all over the highways. (Causing all kinds of tire punctures! )
    https://www.youtube.com/watch?v=BVGOtumdDLY
    Quote Originally Posted by Aracknoid View Post
    Good Luck
    A broken or loose tire chain would wreak havoc on belts and plastic components. I would not use chains under any circumstances. Also, chains are usually made for slow speed operation. 30 or so is pushing the limit.
    Mar 2016
    Willis, Michigan
    Holy Moly! The stuff people come up with!
    Oh, and FWIW about MI, it's actually not illegal, per se, to use studded tires, it's just that the mfrs must prove that their product will do zero damage to paved roads, and zero mfrs have presented acceptable stats. I don't know if they're incapable of producing a harmless stud, or if they just don't care to try. But it sure is a PITA, 'cuz I really relied on my studded tires in the hills and mountains of upstate NY, and I wish I could use them here. They do make a difference.
    2003 F250 SuperDuty
    Vermont
    I so the same here! Due to insurance purposes. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Quote Originally Posted by griffontamer View Post
    Hi folks,
    IMO, you would want to change all three to winter tires, not just all season. But traction will still be an issue I think because there is so much less weight on the tires, both for drive and steering.
    May 2015
    Arlington, WA
    You guys have made some good points... I didn't want to elaborate too much but in the back of my mind I have thoughts of building a dedicated "adventure" Spyder that can go out and play where I wouldn't take the shiny new F3S... I actually bought my white RS-S with that in mind but then foolishly sold it later (trying to be responsible, whatever that is!), now I miss it! Anyway, I appreciate the replies and it sounds like it's doable if one uses their brain, which I generally try to do...
    And Mike, don't worry, I won't do anything TOO crazy
    Aug 2012
    CO
    The more I read this thread the more I think I should ditch the "summer tread" tires. My Spyder is actually our all weather two up ride. When it's nice out we usually ride two wheelers, saving the Spyder for touring in all sorts of weather and in winter when roads are sketchy. In that vein I should probably look at all season tires. We'll take Spydie out when there's frost on the road - or run it through patches of snow in early spring or winter. Pure winter tires are too soft to last, but a set of aggressive tread all seasons.. hmmm...maybe.
    JLohPhotos
    The two front tires act as two nice little snow plows. Snow tread or not, that extra resistance will cause the rear tire to break loose.
    I am a pretty gung ho ryder. I have tried riding in snow and ice. It's your money, it's your spyder, do what you want and be safe out there. Mine stays parked from first to last black ice.
