Results 26 to 50 of 65
  1. #26
    Oct 2015
    Cumming, Ga
    BRP harness has nothing to do with nanny. In fact, it draws power for the trailer lights direct from the battery just like the Show Chrome one does. The difference is the wire from the battery is already in the connector for the trailer adapter and is fed by a 10 amp fuse in the fuse box.
    You are correct about the nanny. It is the BRP control module that doesn't like other trailers. I know I went through two of them before I switched to Show Chrome. No problems since.
  2. #27
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Ex-Rocket View Post
    Does anybody know what pins are what , on the square 4 pole connector of the trailer hitch? One is a male and the other 3 are female.
    Wire colors are the same as I explain above.
    White is ground. Female socket.
    Brown is tail/running lights.
    Green right turn/brake
    Yellow left turn/brake.
    So if your trailer was wired correctly to wire color standard. You would attach the white to white. Brown to brown. Green to green. Yellow to yellow.
  3. #28
    Sep 2016
    Minnesota
    I have the same issue. A 2016 F3-T with the BRP hitch and wire harness (4 pin square connection) and an Aluma MCT trailer with the same 5 pin round connection.
    I have checked with three sources, including an Aluma dealer service department. All three agree there is no adapter available to simply convert the connections.
    I have attempted to contact electrical connection through its website but never got a response. It appears the trailer may have to be rewired and a couple lights switched out
  4. #29
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by Hatter View Post
    You're going to have to cut the 5 pin round connector off and then splice in a new 4 pole square connector into the existing wiring. I bought mine on Ebay and its a Hopkins 11147975 4 pole square set. Just do a search on Ebay and several will come up. Mine cost $7.90 with free shipping.
    What year is your Aluma MCT trailer? Mine is a 2004 and the color of the wires in the tongue are White, Yellow, Green, Brown and Red. As per Billybovine the red wire is not used. Billy said just to match up the colors with the new Hopkins 4 pole connector and you should be good to go. I just ordered the new connectors today and won't have them till next Tuesday. I will report back when I get it wired and let you know if it worked or not.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
  5. #30
    Sep 2016
    Minnesota
    My MCT is a 2008. The connection is buried in factory shrink wrap so I can't see the color of the wires.
    If this is of interest, you can get an MCT wiring schematic from the Aluma website. Click the drop down menu from 'Customer Support' on the
    Home page. Then click on FAQ. #7 of FAQ will have a link to the schematic.
    Please keep us advised on your progress.
  6. #31
    Jul 2011
    According to the wiring diagram you pointed out. The Aluma trailer has amber turn signals. Then the red wire is used for brake lights. Ex-Rocket says his does not have amber turn signals. That would make the red wire in his trailer obsolete.
    So the question is and it is very important. Does your trailer have amber turn signal lights?
  7. #32
    Mar 2013
    Marion, Arkansas
    Ok Update: Billy I finally got around and did a temporary wiring of the BRP module which is the Hopkins square 4 wire plug. I matched white to white, brown to brown, yellow to yellow and green to green. All the lights work, turn signals, running lights etc. except the brake lights. I did not use the red wire from the trailer. I looked at how the rear brake lights are wired and I only have 3 wires going to the rear lights. On the right rear light, I have a Brown, Green and White wires. On the left side, I have Brown, Yellow and White. And printed on the exterior of the rear lights is, Tail, signal and ground. Does the whole trailer need to be rewired or do the rear lights need to be changed out? I'm kind of lost now. Anyone with help?
  8. #33
    Jul 2011
    3 wires into each rear light and 1 of them is ground (white), 2nd is running lights (brown), the other is either green or yellow depending on the side. That's perfect.
    Since the brake is combined with with the turn signals. Same wires and same bulbs. If the turn signals work the brake lights must work. How are you testing the brake lights?
    PS Brake lights will flash on one side if signal light is on.
  9. #34
    Mar 2013
    Marion, Arkansas
    The way I'm testing them is with the ignition switch just turned on but bike is not running. With no turn signals on and just the running lights lite up, I press on the brake pedal and the brake lights on the bike come on but the brake lights on the trailer do not. Should I be testing some other way?
  10. #35
    Mar 2013
    Marion, Arkansas
    I forgot to mention one thing in the way I'm checking the system out. I don't have the trailer sitting on the hitch ball. Would that make any difference? I don't see how it would except for the grounding of the trailer through the hitch ball. Anybody know?
  11. #36
    No, the trailer does not need to be on the ball. Did you get the BRP trailer hitch kit? If so, how did you connect the module into the bike wiring? The bike wiring is 5 wire which means the turn signals are separate from the brake lights. The module should have six wires coming into it, five to connect to the bike light wires and one to go to battery. Then there are 4 wires coming out of it. It looks to me like the bike brake light signal isn't going into the module. If the module you got has only 5 wires going into it, you got the wrong module.
  12. #37
    Jul 2011
    There must be something wrong with the trailer harness wiring in the Spyder. If you have a 12v test light or a DC voltage tester. Test the output at the plug. The green wire and the yellow wire should be 12V when the brakes are applied. If you can't test it yourself. Take it back to whoever installed the harness and tell them to test it and fix it. They should have tested it before leaving the shop in the first place.
  13. #38
    Mar 2013
    Marion, Arkansas
    I had my dealer install the module and trailer hitch. Yes it is a BRP trailer hitch kit. So I'm not sure how it is wired. It took them about 2 hours to complete the work. I do have a DVM and that how I checked the square 4 pin connector that is coming from the bike. But all I checked was the running lights and turn signals as I was by myself and it was impossible to check as DVM leads were to short to check the 12 VDC when the brake pedal is depressed. I guess a trip back to the dealer is do, but I will check to see if there is 12 VDC when the brake pedal is pressed when I can get someone to help with the checking. Thanks for everybody's help. It is much appreciated. I will get back when I either check the voltage or take the bike back to the dealer.
  14. #39
    Mar 2013
    Marion, Arkansas
    UPDATE: Today I checked to make sure that I had 12VDC at the 4 pin square connector coming from the BRP module and it turned out I did. I was checking from the ground lug to either the green or the yellow wires and I had 12 volts when either the turn signal was turn on or if I hit the brake pedal. But when I hook everything it up to the trailer via the 4 pin square connector everything works except the brake lights. Running lights works, both turn signals work but no brake lights when the brake pedal is pushed.
    Question: Remember my trailer was wired using 5 wires which included a red wire for the brakes. My question is just where is that red wire taped into on the trailer? What I can't understand is if the turn signals work, why don't the brake lights work because the same 2 wires, green and yellow are used for the signals and the brakes. So I'm guessing that somewhere in the trailer wiring the red wire is taped into some other wire I guess. I am loss on this folks. Need HELP.
  15. #40
    Do you have red or amber turn signals?
    Sent from my SM-T350 using Tapatalk
  16. #41
    Mar 2013
    Marion, Arkansas
    red only
  17. #42
    Something isn't adding up. If you have voltage on the yellow and green wires at the connector with either the turn signal on or the brake light on and a red turn signal bulb on the trailer flashes when the bike turn signal is on, then that same bulb has to be lit when the brake is on, unless there is some sort of screwed up cross wiring between the lights somehow. Apply power to the red wire and see if you get a separate pair of bulbs to light up. You won't be using those bulbs with the four wire configuration. Are the bulbs for the turn signals and tail lights separate bulbs, or a dual filament bulb? Do your voltage tests again but connect the ground side of the voltmeter to the bike chassis, not the ground wire in the connector. Let us know what you see then. There may be some miswiring with the module connections.
  18. #43
    Mar 2013
    Marion, Arkansas
    I haven't done anymore voltage checking but wanted to post the pictures of the rear running/brake/ turn signal lights that are mounted on my trailer. It looks like it a single bulb with a double filament. It is an enclosed light fixture as you can see from the pictures. I took an outside picture and also what it looks like on the inside where the connector plugs unto the light enclosure.
  19. #44
    Sep 2007
    Rome, WI and Mayfield, KY
    Is there any chance a converter is stashed under the trailer? My trailer is a 4 wire trailer. My Spyder harness is a ShowChrome 5 wire harness. I stashed a 5 to 4 converter under the trailer, on top of the tounge. I ran a 4 wire loop to the coupler area so I can use either 4 or 5 but if I had not done that, the brakes wouldn't light using 4. The fact you have a red wire in there sounds like a converter exists somewhere.
    Lucky
    2015 RTS SE6
    2008 Harley Ultra
    1999 BMW R1200C
    1986 Harley Electraglide
  20. #45
    Quote Originally Posted by Lucky View Post
    I think you are on to something.
  21. #46
    Jul 2011
    I would agree. The trailer must have a 3 to 2 converter built in.
  22. #47
    Mar 2013
    Marion, Arkansas
    Just where would the converter be? Just what am I looking for? Size and shape of converter. If their is a converter somewhere what does that mean? Will the trailer need to be rewired or what?
  23. #48
    Jul 2011
    Your options are.
    1. Rewire the trailer. Find and bypass the converter or diodes in the harness.
    2. Buy and build a 3 to 2 converter that goes between the Spyder and trailer.
    3. Remove the BRP 4 wire trailer harness from the Spyder and replace with a Show Chrome 5 wire harness.
  24. #49
    Mar 2013
    Marion, Arkansas
    and here I thought this would be easy
  25. #50
    Mar 2013
    Marion, Arkansas
    Lucky YOU are the MAN. I got to digging into the trailer wiring and I found a 3 to 2 converter buried. Ok, now the question. Can I just cut off the converter and then just match up the wires, white to white, yellow to yellow, green to green and brown to brown? Also took a couple of pictures to show everybody what I got. I found the converter tucked into the tongue area of the trailer. I know I'm not done yet but hopefully their is a light at the end of the tunnel.
