Results 1 to 24 of 24
    Sep 2016
    Lewiston , Maine USA
    Default Driving lights on A Arms?
    Anybody done this DIY?
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    I bought these
    http://store.valueaccessories.net/Da...AMSpyderl.aspx
    but due to the season (we got another 6" of snow yesterday, and it's still snowing) I haven't put them on yet.
    I bought the dual arm LED's with blinkers
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Very Active Member JimVonBaden's Avatar
    Oct 2016
    NoVA
    I've seen it done, but I prefer to mount them on a firm surface that doesn't move so much.
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
    May 2013
    Apex, N.C.
    Quote Originally Posted by JimVonBaden View Post
    That is what I would like to do on my RSS. Was the install difficult?, and where did you get the lights from? If you have a video or pictures in a step-by-step format, please post a link.
    Thanks,
    ​2012 RS sm5
    Oct 2016
    NoVA
    Quote Originally Posted by blacklightning View Post
    Thanks,
    No video, but lots of pictures and descriptions in the My Spyder Mods section of the forum. http://www.spyderlovers.com/forums/s...fe-s-2013-ST-S
    The lights were $18 each and very good. I have used them on several other bikes: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    The switch was $8, and plug and play to the existing wiring harness: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I used the existing aux wiring and just reused the dummy plug. More details on the referenced thread. All in all it took me about 3 hours, a lot of it removing and installing bodywork.
    Jim
    2013 ST-S (wife's)
    Sep 2013
    Houston
    We have installed several sets like this from Spyderpops. They work very well indeed.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default YOU MEAN
    LIKE THESE....?
    20160614_123517.jpg 20160615_085443 (1).jpg 20160615_085629 (1).jpg 20160615_085429 (1).jpg
    MY WIFE SAYS SHE CAN READ A NEWSPAPER BY THESE, 100 YARDS AWAY.....
    THEY SURELY DO LIGHT-UP THE NIGHT....
    $35 on AMAZON....
    DAN P
    EASLEY, SC
    SPYD3R
    I had them installed by the dealer when I purchased the 2014 new. After a year or so, the connections were melted by the "heat" from the radiator. I had to remove them. I installed a Spyderpops lighted bump skid and that has been working well for me.
    Jul 2016
    Kamloops B.C.
    as I haven't installed mine yet, is there a way you could recommend them to be installed that wouldn't melt the connections? I'll be honest, I haven't even opened the box to look at the "distructions" yet.
    Thanks
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Quote Originally Posted by bcer960 View Post
    Thanks
    The wires closest to the radiator location are the vulnerable ones. I decided to go with the bumpskid since the dealer screwed up the initial installation and I did not want to get into a potential "hassle" situation. Brightness wise, the A arm lights were better. Overall, the bumpskid looks better--IMO. I have the driving lights as well on mine, so checking off the boxes, I am better off now than before.
    Jun 2015
    Lees Summit, MO
    Default lights
    Installed mine last week from tricled with no problems at all. Very easy and happy with the results. I didn't run my wires by the radiator at all.
    2015 Special Edition , Red and black
    Jul 2016
    Kamloops B.C.
    Thanks for letting me know. I didn't know the heat was a problem, but now will lake sure it isn't when I install
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Oct 2015
    Lynden, WA
    Default A Arm Driving lights
    Its really no problem to install on the A Arms.
    Here is my setup. Have used this setup for 1 year with no issues.
    Driving lights are from CREE – no problems with the lights being waterproof. Mounted on the lower A frames.
    Route the wiring on the A Arm with the factory wiring for the fender lights. It will be away from the radiator heat.
    Connection to factory wiring for Driving/Fog lights
    Driving light switch from EBay that plugs into the factory harness.
    Driving lights
    http://www.ebay.com/itm/2-x-CREE-Waterproof-Motorcycle-10W-LED-Work-Driving-Fog-Head-Spot-Light-Lamp-/252624699377?hash=item3ad19afff1:g:bxYAAOSwB09YH-fT&vxp=mtr
    Marine Switches for Driving lights and Heated Grips. Waterproof and an exact fit to the
    Spyder switch cutouts.
    Right now I have SPDT. Works great. Although all you really need is an SPST ON-OFF switch.
    http://www.ebay.com/itm/Waterproof-MARINE-BOAT-CAR-Rocker-Switch-12V-SPDT-ON-OFF-ON-4-PIN-Red-LED-Light-/322343377148?hash=item4b0d2998fc
    Feb 2016
    HAWTHORNE nj
    Default Instalation
    Hi guys I am in the middle of installing driving lights and I am running into some issues. where else do I ground the lights. I ran the harness up the left side .I just bought a relay and the harness just to make sure nothing goes up in flames like the switch.
    Default GROUNDING
    Quote Originally Posted by MOSESS View Post
    ?????....What do you mean by ...." where else do I ground " .... if you have grounded the system, it's grounded...... ..... Mike
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    I bought and installed Driving Lights by Rigid Industries D2 driving lights. I installed them on to of a arms.
    I used the plug and play wiring harness complete with waterproof switch.
    I wired them into an auxiliary fuse block on the keyed side ,so that I can forget to turn them off when the spyder is not running.
    I wire all of the electronic accessories through the auxiliary fuse block.
    Oct 2016
    Faribault, MN
    Quote Originally Posted by Marker View Post
    NICE! Looking mount option, looks like it would give you a great pattern. Did you compare before and after (or with and without) lighting footprint? How did you mount them to the top of the A Arms?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    I got cheapy LED cobb lights from ebay and mounted them on the A arms. I spliced into the fender tip lights and have run them for two seasons now with no problems. In this position you get a nice effect from the side because the lights shine thru the wheels and give a strobe effect when moving.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by Bensonoid View Post
    Have there been any issues with riding at highway speeds with these? I have a set and wondered if they would handle the speed of 75+ mph
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Jun 2016
    Harrington, Australia
    My Tricled driving lights work brilliantly attached to the front fender bolts -
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    May 2014
    Benson, NY
    Quote Originally Posted by M109Dreamer View Post
    I used a piece of 1/2 x 1/2 aluminum angle and 1/2 inch 3M double sided tape to mount them and 75+ mph has no effect. When I stuck them on one was off just a bit and I thought no problem I'll just pop it off and reposition it. It wouldn't " pop off " so rather than rip and scrape to get it off I left it. Those puppies are there to stay.
    Sena 20s
    Sep 2013
    Houston
    The
    dealer installed them backwards. The connections are out at the wheel hub end, not behind the radiator. I also use a black tywrap around the a arm on the inboard end of the strip. Out of sight but it keeps the adhesive from starting to peel where they get hot from the radiator. I have a number of sets that have been in service for a couple years now and no trouble.
    Mar 2011
    Jackson, MS
    Ok, thx.
