Digital Display 2010 RT
The Digital Display will not come on. Sometimes after riding for a few miles it will come on and work ok until I turn the Spyder off and it sets for an hour or so. Everyone is saying it is the Mode switch, how do I test it?
Bernie, it sounds like you should pick up a service manual. You can download one online for $20 or so I buy mine from Midwest Manuals on eBay. Good luck with your repairs
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Little checking..
I would check the connections to the cluster. Sometimes the connection is loose or a pin is out of place. If any work has been done in that area you should check there for sure. The mode button would not make the screen disappear more like not move to the next screen and not let you start the engine. But as Ann stated above a manual will have some test you can do....
2012 RS sm5
The fact that it might work after a couple of miles of movement, tells me that you've got an intermittent loose connection.
