Results 1 to 12 of 12
    Jul 2016
    Arizona
    Default F3 headlight adjustment
    Hi all..I have a 2016 F3 Ltd and need to adjust the headlights. I can see a cable coming from the lights but I can't find the end. Do I need to take more plastic off??
    Thanks..
    Jul 2010
    Las Vegas, NV
    Default Headlight
    I have one in the shop-I'll find it for you tomorrow. Joe
    Joe Meyer
    Apr 2012
    USA Andrews, TX
    Look in the manual that came with the bike, it showa the adjustment procedure.
    Aug 2007
    Springfield, MO
    It's just above the access panels on top. They are really hard to get to and the way they turn a 90 they are hard to adjust. We remove them from the stock mounting and let them hang when we change out to LED.
    Default Suggestion....
    Best way to adjust to your liking is for you to be on the spyder and someone else adjust the lights. Being alone most of the time I use cement bags to replace the wieght. The level will also change with a passenger . I miss the old days when I just leaned forward and smacked the head light to adjust it...
    Jul 2016
    Arizona
    Default Thanks all
    Thanks... I'll do the same..
    Quote Originally Posted by Lamonster View Post
    Aug 2007
    Springfield, MO
    Quote Originally Posted by kickinbar View Post
    Just pop that clip off and push the adjuster through the hole and you'll be good.
    Sep 2013
    Mill Creek, WA
    Just installed LED bulbs in my wife's 2019 F3-T and was trying to adjust them. Heads up, the cable actuated adjuster pictured earlier in this thread adjust the lights horizontally only. To adjust each light vertically you'll need to take a couple of panels off and use a ball end hex with an extension to reach the vertical adjustment for each light. 3 panels on each side need to come off, a bit confusing if it's your first time removing them.
    Jun 2016
    Harrington, Australia
    Best way to adjust to your liking is for you to be on the spyder and someone else adjust the lights. Being alone most of the time I use cement bags to replace the wieght..
    Hahaha.....I would have to balance 6 25kg bags on the seat, Gene
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2018
    New Jersey
    RandyL, I had no idea we had vert and horz adjustment. I will have to recheck my alignment seeings how am being flashed by on coming traffic. So is the one shown in the Lamonster post the vert or horz???
    2018 F3L , Blue
    Apr 2016
    St. Charles IL
    Quote Originally Posted by jlc41 View Post
    I had to adjust my headlights on my '19 F3 LTD after installing LED's from Lamonster. The VERTICAL adjustment is way inside by the headlight itself. It's a WHITE nylon nut. I had to use TWO extensions to get at it. You don't need a ratchet, you can turn it by hand. I didn't know the headlights had a HORIZONTAL adjustment....
    Jul 2018
    New Jersey
    40Xshooter, thanks for the come back.
    2018 F3L , Blue
