Results 1 to 11 of 11
    Active Member Greenhorse's Avatar
    Jun 2013
    RI
    Default Passenger handle
    Has anyone modified the passenger handle? I would like to cut-away the handles that stick out from under the seat. An easy job, but I'm not sure if there is anything "important " embedded in the center of handle portion.
    Thanks
    Default PASS. HANDLES
    If they are heated there will be wires connected to the harness. If not just un-bolt them ........ Mike
    Default Depends....
    Standard on the GS/RS/RSS and ST with no electrics involved (heated grips, radio controls etc) should be able to cut them off. Being a one piece unit you could remove it and add spacers where needed. Not sure why you would want to they are handy for many reasons besides the passenger holding on...unless you just want the passenger to hold on to you.....
    ​2012 RS sm5
    Active Member Pappy John's Avatar
    May 2012
    Susquehanna Valley
    Some day you're going to want to strap an extra bag behind you back there, and you're going to say, "GAAH!"
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default LAMONT
    CHECK OUT LAMONTS WEBSITE, HE SELLS OPTIONAL PASSENGER GRAB RAILS.... HE MAY HAVE WHAT YOU NEED....
    imo, DON'T DO IT...
    DAN P
    SPYD3R
    Default PASSENGER HANDLES
    A thought, if you ever have to move the Spyder .....what is better than those handles ???, nothing else comes close to the strength of them ....... jmho, Mike
    Jun 2013
    RI
    Relax people, it's a look to use when I have the mono seat cowl on the bike. And, of course I'm not going to cut the stock handle, I'm buying a spare set of handles.
    Very Active Member kep-up's Avatar
    Nov 2014
    Mountville, PA
    You actually need them to haul a case of Labatt Blue bottles in a safe manner.
    Jun 2013
    RI
    Well, that's the best reason I've heard yet on why to keep them. But, the Spyder has so much storage that I'd rather keep the, in the frunk that I am converting into a giant cooler! ��
    Quote Originally Posted by kep-up View Post
    Jul 2008
    Mesa AZ
    Default Passenger Handles
    I didn't see any handles on Lamont's site. Could some one post a link to them so I can check them out. My SO finds the stock ones too low to use safely. Thanks.
    http://www.lamonstergarage.com/f3-grabrail/
    He has them for the F-3, but I don't know if they'll adapt...
    You probably should give him a call.
