air bag motor not running-2015 RT-Limited
I have a 2015 RT-Limited and my air ride system motor pump is no longer running and I get a "MANUAL" note on the dashboard. Can anyone tell me what fuse and where it is located to check so I can see if it is that simple or not?
On my old 2012 RT-SE5- Condensation had gotten into the motor and fitting and cracked and failed when temperatures got to freezing. I am wondering if I am having the same situation now on my 2015 RT-Limited. I would have thought BRP would have fixed that but maybe not. When it happened on my old 2012, it was covered under warranty and my dealer put better fittings in it and never had issues again.
Thanks for you help! ;)
Thanks- I checked what you said and it's not the fuse!
Quote:
Originally Posted by
IdahoMtnSpyder
Do the horn, heated grips, and fog lights work? If so, the fuse is good. They're all on the same fuse with the compressor.
Wish these things were easier to work on but it looks like I am going to have to haul it to my dealer down in Springfield. Trying to decide when I can do that with the holidays and winter forecast coming up next week.
What's interesting is I started the bike up this afternoon and the things you said to check I did and they all work. I am not getting the "MANUAL" message like I did before about air bag system. I can now use the toggle switch and move it from soft to firm but nothing is letting out pressure or adding it, no sound from the pump.
My next little test will be to air it up manually. Figure I'll put it at 75 PSI and see if it holds or how it acts. With slightly under 2000 miles I wouldn't think it was a hole in the airbag because we never heard the pump running non-stop.
I have a bait station near the bike in the barn where the Spyder is parked but don't think it's rodent related. Even though I did find a dead mouse in the goat trough this afternoon but that was clear at the other end of the barn.
Wish it wasn't winter and wish I was fully retired but getting closer each day! When you are an educator it's hard to get that time to do things like this!
Thanks for your time and help! MERRY CHRISTMAS and HAPPY 2018 to you and yours in IDAHO! ;)
Did all that and still didn't work
Highwayman2013
For the compressor to work the bike must be in gear and the parking brake off.
I did all that and still nothing! Just FYI!
Thanks-Dave- good to know
Fire34
Aired mine up the other day took it up to 60#, scared to go all the way to 70 like the manual says came back and it was back to zero. I did that a couple of times and then called the dealer and told them. I have it put up for the winter. The wife and i are hoping this to be a warranty issue. We bought a 2013 RT Limited used with 10,900 on it, The dealer has repaired a couple of oil leaks for us under warranty, and we are lucky our dealer is only 15 minutes away
Dave
HI Dave!
Thanks for the information. I know my old 2012 had the fittings on the pump crack and broke when moisture from condensation froze inside the fittings and expanded and cracked the fittings. The air bag couldn't even be aired up manually in that situation but BRP had replaced the pump under warranty and the dealer mechanic used better fittings on the pump that they got at a local hardware store. So back then, that is how they dealt with it. This time with my 2015 I am not sure what's going on. I was told when I bought the new RT-Limited that BRP had put better fittings on it. Now I am beginning to wonder but can't confirm what the issue is yet so we will see. Again thank you for your feedback on this too. Merry Christmas! ;)
I will use the Lamonster Air Pump to air it up
Saluda
Bag fills quick, go slow.
I was planning on using Lamont's rechargeable air pump to air up the air bag manually. At least I can dial in the pressure i want and the pump will shut off automatically when it hits the preset pressure.
I figured I'd better not use a normal air compressor or like you said, I'd be in trouble cause it would air up too quickly and well....you know! ;)
Thanks---hadn't noticed the air leaking or motor running excessivly-
Fatcycledaddy
I have a 2015 RTL, had a air line leaking on it causing the compressor to run too much. Line was replaced under warranty, couple months later the compressor stopped and it was replaces under warranty last month.
Now it kicks in a lot less and runs very very quietly.
Wondering about that myself but we had not heard any more pump running then normal and hadn't noticed the rear dipping down or re-adjusting either. Very odd that it just simply up and stopped. I mean it worked one day. Went out and put the key in and started it and immediately got a "MANUAL" orange notice on my screen.
Since then though I don't get that manual warning and the toggle switch moves the firm to soft and soft to firm, just no pump. Very odd!
Thank you for your help! ;)
Just got the pump fixed this week----it failed
Well, thought i'd update you all on the saga!
I finally was able to get my 2015 RT-Limited to the shop, had to wait for "Spring Break" and time off of school to do it. Anyway it was indeed a failed air pump motor and thankfully it was replaced under the 2 year orginal Spyder Warranty. That would have expired at the end of this month! I do have an extended warranty so if it happens again it will be covered. Apparently from what I am hearing, it's a fairly common issue with the Spyders. i had a 2012 and had a pump fail due to moisture that got into the fittings and froze and spliut the fitting which was replaced with brass and never failed again. This one they said has a check valve but was told it's the same motor and apparently they have issues with it.
I saw another thread on here about going to a heavier shock on the rear especilly if riding 2-up. Well, I was told that instead of replacing 1 pump a year let's say, you might go longer before having to replace but there is still an issue so a stronger spring back there isn't going to solve the issues.
For what it is worth, just thought I'd pass on my esperience here.
This pump sounds different then the original one so maybe the original did have an issue. Regardless for 30K for a bike I'd like to think the components would last longer and be more reliable. Heck I have less than 3,000 miles on it so am quite surprised that this happened.
Take care!
