Harbor Freight Jack won't Fit
I have a 2015RT LTD. I just bought the Harbor Freight ATV jack. It won't fit. I'll either need to lift the front a little bit before I use the jack, or I'll have to take the wheels off the jack and lay its frame on the floor. Why doesn't anyone else mention this when they talk about a jack?
Am I seeing suspension sag?
Using a motorcycle lift table for my Spyder
I have an air operated lift table, that I purchased when I still had a motorcycle. I purchased it with the side extensions to accommodate atv's (I also use it for my riding mower). The extensions are mounted on two pipes, so I installed longer pipes to accommodate the extra width of my Spyder. I had to remove the front wheel clamp because of the front of my Spyder. The lift table just is long enough, but it works great.
