Wondering if I should have balancing beads put in my new rear tire? And if yes 2 oz?
Printable View
Yes to the beads, follow the bead manufacturer’s advice for the size of tire.
2oz in fronts - 3oz in rear.
:agree:
Actually with a conversation i had with counteract on monday i would suggest 3oz in front with 4 or 5oz in rear on
225X50r15
When replacing tires, we have seen far more tires with beads clumped and CAUSING the imbalance than ones where the beads actually helped.
You are FAR better off having the tire/wheel assembly correctly balanced and leaving the beads out of the tire. It takes extremely little tire assembly lube to cause the beads to clump.
I Haven't used them on my last 2 Kumhos and they were fine- The tire guy Just puts the red dot in the right place and they have been fine on the rear tire. Front can be balanced on the machine.
Depends on how much soapy solution is used and where. Just minimally spraying on the outer bead works but spraying inside the tire will cause problems. I’ve been using Dyna beads for years with no issues. My dealer uses them automatically. I learned, years ago that we really should have the tire/wheel rebalanced about every 5000 miles which is costly, so beads balance every time you get going.
The only time I used beads in 2015 they clumped badly. I blamed it on the moisture that was coming out of my compressor. I never drained it (10 years). Shame on me.
QUOTE=jcthorne;1401475]When replacing tires, we have seen far more tires with beads clumped and CAUSING the imbalance than ones where the beads actually helped.
You are FAR better off having the tire/wheel assembly correctly balanced and leaving the beads out of the tire. It takes extremely little tire assembly lube to cause the beads to clump.[/QUOTE]
I've used the beads for years with good results, as long as you don't get any tire bead lube or moisture inside.
The Centramatic balancers work even better to me, and take the other issues out of the equation.
The Ryker will have to use beads.
Just installed tires on a tundra & used the bags
The Centramatics will work over multiple tire changes, and balance the entire rotating assembly, not just the tire & wheel.
^^^^^^ :thumbup:
A couple of questions
What exactly are these, how do I know if I need these, and what do they do etc.
Thanks guys
Dave
No bead use, but have had great luck with “Ride On” as a balancing device on two wheelers. Can’t vouch for its leak stop ability luckily
I used the beads in my trailer tires and a couple other vehicles -- no issues. Plan on using the Centramatic Wheel Balancers on the Spyder along with the beads.
