1 year maintenance report
I purchased my used 2012 Spyder RT A&C in May 2016 with 30k miles. In the last 12 months I have replaced the battery (original finally died), replaced the antenna (broken in a wind storm). I added two rear speakers to improve the sound, and due to getting hit by a car I have replaced the rear fender. None of these were really complicated. I just reached 34k miles and I am preparing to do my first oil change. Also according to the previous maintenance record I am going to replace the brake pads. I am lucky that I have a mechanical background, yet nothing has seemed to complicated (except the battery location). In my opinion the Spyder is not very complicated to work on.
one year maintenance report
Congratulations on your purchase; that is a beauty for sure. Have you purchased a shop manual??? If not the green manuals can be purchased online and work fairly well. mostly wear and tear stuff that goes out on these machines and the wrenching is mostly straight forward. The suggestion below about the brakes is good; BajaRon is a great supplier of most things spyder; and if he doesn't have it Spyder pops most likely will!! Enjoy your ride, doing your own wrenching is the best way to learn about the intricacies of your ride IMHO. Just rolled over 40K on mine last month. :yes::clap::ohyea::yikes:
If you are buying brake pads I recommend the EBC pads vs. OEM. The EBC are much better quality than OEM and usually cheaper to boot. :thumbup:
2012 RT Brake pad replacement
Just completed front brake pad replacement on 2012 RT. Purchased new EBC pads $99.00 (thanks KX5062). The process was very simple, however I do have one caution. The replacement EBC pads do not come with the small spring clips, these must be removed from the existing pads and transferred to the new replacement pads. While removing one of these paper clip sized spring clips, it bounced from my needle nose pliers out the garage, hit the driveway and eventually bounced in to the grass to be lost forever. Needless to say my son and searched the driveway and grass for this tiny clip for nearly an hour. Eventually I ended up at the local Can Am dealer, ASK Powersports. Their repair shop could not locate an extra clip, at this point I was near desperation. I was directed to the parts counter where I was told I would have to purchase a new set of Can Am brake pads (clips included) at a cost of $120.00. However, after hearing my story, and realizing I only needed one
paper sized clip, the sales person removed the clip from their stock pads, gave it to me and stated " I'm not going to charge you $120.00 for a paperclip, take it and finish your brakes." A huge smile came over my face. I thanked the salesperson and told him I would remember his graciousness. I took the clip, finished the pad replacement and now the brakes are in new condition as the previous pads were more than half way worn. So a shout out to ASK Powersports.
http://i.ebayimg.com/images/g/eKEAAO...LwQ/s-l500.jpg
