when replacing y-gasket easier to?
take the muffler down first then the pipe or take them down as one unit?
do i have to change both gaskets at the same time? i was afraid when i pull the pipes down, left one may get damaged even if that one is still in good shape. i gotta take this spyder to dynojet asap but honda dealer only had one available...
thank you in advance.
Easier with the muffler off...
I've changed my three using the honda GL1800 gaskets and experienced no problems. It is easier if you have help so you can get both sides up evenly and that helps get them in the receiving side. /Ken
Negative... I need to clarify...
I have three spyders and have changed all three upper y gaskets to the GL1800 gaskets. Sorry I didn't clarify that a little better.
No I am still searching for a sub on that lower gasket. I've done some in-depth part searches before but this one gasket is by far the most in-depth I've ever done. Right now it seems that no-one and I do mean no-one makes this lower gasket except the contractor that makes them for BRP.
M2Wild... I sure do like your avitar... that skier only catches the mist. /Ken
