Now available! F3 Stock Seat Passenger Backrests for F3 and F3-S
The passenger backrest easily installs into the included bracket that mounts under your Spyder F3 stock passenger seat. The passenger backrest is secured to the mount by a bolt, but can quickly be removed by removing the passenger seat, removing the bolt, and reinstalling the passenger seat.This leaves the passenger backrest mount installed even when the backrest is not in use. This Stock Seat Passenger Backrest fits F3 and F3-S. It does not fit the F3-T.
- Pad measures 7" high by 10" wide by 1.5" thick.
- Built using the same memory foam as our seats.
- Backrest folds down forward for easily mounting and dismounting your SpyderŪ.
- Adjustment forward and back is more than 2 inches.
- Adjusts with a thumb screw while you're riding.
Check them out here:
http://ultimateseats.ca/can-am-spyde...enger-backrest
They are available and ready to ship now!
