1 Attachment(s)
All 2013-up with Brembo brakes (Parking brake arm bolt check) WARNING
Two days ago while out for a ride, the bracket that bolts on to the rear brake caliper and that the brake cable hooks on to fell off my bike. I did not notice this till I got home and tried to set the parking brake. Somehow the bolt must have vibrated loose. The problem, BRP does not offer the bracket seperately. But you can buy the spring and bolt which holds the arm onto the caliper. Make sure the bolt is good and tight when ever you have brakes serviced.
BRP should make this available. Why force us to buy a whole new exspensive caliper assembly, when all we need is the Arm, Spring, & Bolt - probably less than $60.00. We've already spent enough for the bike.
Attached Below is the picture of the Bracket in question. It's bolted to the caliper with spring attached at the bottom cable hooked at the top. Make sure this bolt is tight each time you have brakes done.
