Longer USB cable on my 2018 RT Limited spyder PROBLEM
Hello All fellow spyder riders.
I got a good one.
I have a 2018 spyder RT Limited
The USB plug is in the frunk, but I want my iphone on the handle bars.
I was able to bring a lighting and a USB coupler cable from the frunk to the handle bars, but it will only connect to the BRP connect when the iphone battery is almost fully charged.
If I use a short lighting cable from the frunk, it works fine.
It also does not charge very fast too.
No matter what combination of cables I use, it just wont connect with a long USB cable when the Iphone is discharged.
Has any one used a powered USB hub on there spyder?
Thank you
JD
Same issue and hoping this will solve it!
Found this on the Lamonster Garage site and it looks like it will be the solution! Headed up there this week for the Spyders in the Ozarks event on my new 2018 RTL and plan to have this installed. Will report back! http://www.lamonstergarage.com/lamon...er-motorcycle/
