3 Attachment(s)
Cargo stability problem solved!
Chupaca, I got to thinking about your recent suggestion on my "I stumped BRP" thread where I discussed needing a high horizontal tie-in to vertically secure my passenger seat cargo. You suggested a luggage rack. I said it'd just be in the way, but when I mentioned this to the guys at River Raisin Powersports, they showed me the Rivco adjustable rack (https://rivcoproducts.com/shop-by-mo...spyder-rt.html). Bingo. Nice and compact. My husband and I took about half an hour to install it, and today I tested a load of small bags. What a difference. No more suddenly finding myself with a backrest that's slowly folding me into the crotchrocket position! I threw in the 3rd pic just to show the rack fully extended. Thanks, Chupaca. :)
1 Attachment(s)
Cargo stability problem persists ...
I too have installed the Rivco trunk mount. LOVE IT!
As you can see in the picture, we have utilized a Nelson-Rigg bag on top as our day pack. It holds our cameras, purse, selfie-stick and several other items needed during trips. Unfortunately, at times the 20 lbs. limit *may* be exceeded, but even when observing the weight restrictions, we're seeing the trunk top settle down, crushing the weather seal around the edges.
When I had my Goldwind, I was able to solve this same problem with an add-on "Trunk Support". There are a couple models available, but either model seemed like it would work to solve the problem. Here is an example of one of the supports: http://wingriderproducts.com/index.html
I've been contemplating purchasing another to try to modify to fit our RT, but I thought it best to run it by the forum and get the groups weigh-in before I dropped $60.
Not sure others have had the same issue, or what you've done about it, but I at least wanted to ask ..
Mark
