Spyder Dies Momentarily - anyone else had this issue?
My old GS SM5 has shut down momentarily on 3 occasions over the last few months. Twice it's done it while slowing to make a turn off the throttle; yesterday it did it while cruising at 80kph with immediate power loss then within a second or two, the dash lights and dials do the start routine with 'press mode button' as if the bike had been parked and ignition just turned on, but the engine kicks back on even before getting to press the mode button. The trike's only non-stock electrical accessory is heated grips, which have been there for years. No fault code. I have owned the trike since new. It has 103,000km on the odometer.
After it happened the second time I fitted a new battery a month ago as the one in there was 5-6 years old, so I was unpleasantly surprised when it did it yesterday in the middle of a 400km ride with my beloved pillion. There have been no other symptoms of anything amiss. I will check the relays and fuses for security and cleanliness today.
I don't recall ever reading of such an issue - has anyone else?
TIA.
