Show Chrome Floor Boards 41-176
Has anyone on here installed or tried to install Show Chrome driver floorboards part number 41-176 on a Can Am Spyder RT? I have a 2015 Spyder RT which I purchased floorboards from Amazon and they were to fit any RT 2010 on. I received them today and installed the left side with no problem. It looked real good. I proceeded to install the right side. They tell you to remove the bolt and the brake petal. The problem is you cannot get the bolt out even far enough to remove the brake petal. The bolt is too long to get it out. You are to disregard the bolt same as on the left side and replace it with a longer one. You cannot get the one out let alone put a longer one in. I ever removed the plastic on the right side thinking I might find something to remove to get the bolt out. I cannot find any way to install the right side. There would be no problem installing them if you could exchange bolts. I worked over four hours and finely put everything back and hope I can return them. The boards look great and I would like to have them.
After reading the instruction again which do not come with the boards. I downloaded it on the web. The longer bolts go through the new boards from the outer side. I can remove the foot beg and saw an inch or so off the original bolt and it would come out then. Then the new longer bolts go through the out side and just a lock nut goes inside. I think I just got into to big of hurry and did not read everything. They don't say any thing about the problem getting the right side peg bolt out.
