I did exactly what Mike said...
Quote:
Originally Posted by
BLUEKNIGHT911
OK as you face the open Frunk .... look at the Latch .... there are two 10 mm nuts ( they are on fixed studs like on your wheels ) ...... You should remove the left plastic cover to get better access ..... and the DEEP socket is better for the ACTUAL Removal of the Latch !! ... An open end wrench will work for a little adjusting ...... So you are probably doing this because the hood doesn't latch EASILY or the hood doesn't open EASILY ...... so if you loosen the bolts enough to put a screw driver at the front you can LEVER it up a VERY little .... tighten nuts and see if that was enough ..... if not loosen and lever it up a touch more ...again tighten nuts .... keep repeating until your are happy with how it works ................PS as someone said don't use WD40 as a LUBRICANT ..... it's not a Lubricant , it's used to LOOSEN things but doesn't work as a long term lubricant............ Mike :thumbup:
...my frunk now works easily to close and to open. Thanks - But... what do I use to lubricate this system and where do I use it?
