Have a ST- Limited, which I trickle charge when not riding, and if I don't ride it for more then a day or two it will stall two or three times before I can drive it away, any thoughts on why.:helpsmilie:
Printable View
That's odd. Is it stored where its dry? Have you actually checked voltage? Do you warm it up for a couple minutes? (Idle)
How does it run afterwards...
It runs find afterwards, stored in a double attached garage. Let it warm up, watch it rev up to 2500rpm not touching the trottle then when rpm settles down to 1400 rpm it will stall, start it back up back it out of garage and will stall again, and could stall again before getting out of driveway, after that runs fine
My 2013 RT Limited does the same. I have 8000 miles on it. No telling when it wants to do the stall thing.
That is not acceptable, even if it seems to be common. It could even be dangerous under certain conditions. Report it to your dealer and lean on them until it is cured. BRP can't understand that they have a problem unless owners report them. I'd suggest getting a claim number from Customer Care to make sure it goes beyond the dealership. Don't let them snowball you with "It's normal".
