on my, new to me, 2016 Spider RT Limited, it had one adjustment cable on the left headlight globe but none on the right. Leaving me with the question Should there be one on each side or just one on the left side?
Hank
Printable View
Hank
From my owner manualThe owner manual seems quite clear there are two adjusters.Quote:
Headlights Aiming Adjustment
1. Remove both side panels. Refer to
BODY PANELS in the EQUIPMENT
subsection.
2. To adjust headlight beam, turn the
adjustment knob. Adjust both head
lights evenly.
my '16 had 2. Did someone do some work and forget to put the adjuster back in its place?
should be two:dontknow:
will be 2. somebody just had the side panel off and didn't put cable thru hole. or big nut fell off and cable slipped inside. it should be still attached to light housing
Did you see our responses when you asked about this about two weeks ago? https://www.spyderlovers.com/forums/...is-this-normal
:chat:..... Diffently Should Have a Cable Attached to Each Light Fixture.
