Michelin HydroEdge Radial Tire - 215/60R15 93T
Where can I purchase this tire at? Went on the Amazon site and ask me to verify the auto first before allowing me to purchase it.
John:doorag:
how about a michelin defender
Seeing as how the Hydro edge is discontinued how about the Defender as a replacement??? I got a Defender 215/60/15 but it appears to be much taller then the stock tire at 225/50/15.
My stock tire lasted 7300 mi. I replaced it with a Somomoto 215/60/15. But as I remember the Somo was vary close to the same highth and circumference as the stock 225/50/15.
When I stand the new Michelin Defender beside the original worn out stock tire the defender is a good 1.25 inches taller. Of course the stock tire is worn out and the defender is new and never mounted yet.
Is anybody running the Michelin Defender 215/60/15 at present time yet.
The Somomoto is a 75000 mi. tire. I now have 42000 mi on it Has worked great. Getting worn down, thinking of replacing with the Michelin Defender
My bike is 2014 RT-S
tire vetical size versus speedo reading
Quote:
Originally Posted by
BLUEKNIGHT911
.................................Now my Question there are hundreds of Spyderlovers who are now and have been for quite some time using 215 /60-15 rear tires ......why arn't they throwing codes ??????????.........the difference between a 215 vs. 225 in 60 aspect ratio is about .025 % ................so I really don't think it's the tires.....................Question #2 , is it your opinion dealers and Their employee's are always truthful..................Mike :thumbup:
The monitoring pick up sensor is not on the wheel--it's closer to the rim. Thus if all 3 tires have a larger diameter rubber the only error one will see is on the speedo. It doesn't get any simpler than that.
Looks I will need to replace the rear tire on our 2014 RT Limited soon and from what I read here, the Michelin HydroEdge Radial Tire - 215/60R15 93T is the tire of choice.
Has this tire been discontinued? If so, what would be the closest equivalent be?
Thank you in advance for your kind help.
Hydro - Edge Tire .........GONE
Benggolf
If you search on-line you might be able to find one ....however it will be at least 4 yrs old .... which is not terrible .... but it's getting there ..... Michelin has two tires that might actually be better than the Hydro-Edge ..... the Premier A/S ....and the New Defender T & H .....both are only available in 205/60-15 size but this isn't really an issue .......... both have excellent ratings and I would buy either one ..... Mike ......PS use a psi of 18 and they will preform at their best on any Spyder ................Mike :thumbup:
