I bought a Spyder RT limited 2014 version and noticed that is missing the push-button electronic front cargo release?? And the fog button does not come as standard on the RT-S and limited series?
Thanks in advance.
Printable View
Thanks in advance.
The Frunk release probably is part of the ignition switch. Both my RTs were like that.
And the headlight configuration is slightly different in Europe I think.
What is "fog lights" here might be the actual headlights for you......or something similar.
I think what you are seeing is probably "normal" for where you are.
The switch for the front trunk was eliminated in 2013, now you can only use the key. Easy Rider is correct, European models have separate high and low lamps, our fog lights are your low beams.
Yup! They took that away from us in 2014. Every time someone talks about ECO Mode--which they gave us that year--I do the "You took away my electronic trunk release rant." :roflblack::roflblack:
Personally, I liked the convenience. But that is just me. :yes::yes:
:welcome: 1330club :2thumbs:
