2008 GS Gauge Didn't Work......
So it was the 4th of July and I figured it was a good time to take out my old #006 Spyder, the original 2008 GS. Had not been out all year yet, but I always charge the battery every month, have done so since late 2007. And never have replaced the battery.
So I turn the key and the gauge does not light up. Hmm. Try again, no light up. So I pressed the mode button and hit the starter, fired right up with no hesitation, starter spun at normal speed. Maybe two seconds later, gauge lights up. OK, away we go.
I was well over 100 miles into the ride, no issues, then the gauge resets. First it shuts off, then the needles do their index sweep, everything comes back on. Hmm.
Not more than 2-3 miles later it does it again. I figure the gauge might be flaking out on me. I stop at a lake access to get a drink and stretch. Turn the key on, no gauge light up. Damn. So I push the light-on button in front of the throttle, on comes the gauge. Hmm. Could it be the battery? I just had a charger on it, gave me the green light, but I did not actually check the voltage. Pressed the start button, fires right up, no hesitation. Gauge works all the way back home.
Now I am real curious. Put the charger on it, comes right back to green light. Turn the key, no gauge light up. I pull the left side panels and notice corrosion on the positive terminal of the battery. But, I tell myself, this battery is almost 9 years old, screw it, I really should put in a new one. So I pull the battery and check the voltage. To my surprise, it shows 9.7 volts. WTF? Started like a champ, ran like a champ, but the gauge needed more. Damn.
Lesson learned. A $100 battery is sure better than a $350 gauge. Glad I made it home on that ride!
Old Battery Load Tests Fine
Well, my almost nine year old original battery load tests perfectly fine with minimal drop. :gaah:
The reason my gauge didn't light up was a faulty Main Relay 2. I had swapped this relay with the headlight relay early on, but they were both pretty weak to engage so I didn't identify it right away. My fault. :opps:
Removed faulty Tyco relays, installed new style Omron relays, all works well. Problem solved. Lesson learned. :2thumbs:
Now I wonder if I should leave the new battery in there, or yank it and put my old one back in. Tempting.
