F3S issue: passenger floorboard loose
Quote:
Originally Posted by
GaryTheBadger
Your original question was if we had experienced any other F3 issues. After two weeks of ownership, one of the passenger footrests refused to stay up, it kept slowly working it's way to the full-down position.
They were fully tightened. I recall reading other posts with this issue. It looks like only rubber friction is used to keep them up...how to you add more friction? For now, I took them off.
I added another washer to increase friction and mine stays up now! Simple fix.
Only the Spring is different....
monkeyboymorton
BRP does have a more affordable '2 Up' shock for the F3-S which will help with the bottoming. It won't stop it entirely but it is much better than the poor stock one (which they shouldn't really be putting on newly produced models).
Part code is 219400739 - see this thread for details. Edit - thread link would help:
http://www.spyderlovers.com/forums/s...3-two-up-shock
I can appreciate you aren't happy having to spend money on a brand new bike - could try and get the dealer / BRP to change it as a goodwill gesture?
After I bought my F3-S, I did the switch to the heavier duty rear suspension setup. After purchasing the shock/spring "kit", I found that only the spring is different. The shocks have the same part number stamped on them. Going this route (switching only the spring) will save significant $$ (2/3?), but you will need to have, find or buy a special tool to swap the springs.
