I don't ride at night much. Last night my wife had our Spyder out in an RV park and came home after dark. She had no headlights! Today I checked the 30amp headlight fuse under the right side of the seat - no issue there. So then I went ahead and removed the instrument panel to access the bulbs. To do this I had to modify a small screwdriver by bending the flat blade to depress the plastic tabs on the instrument panel.
Then I had to reach inside the front cowling to try and release the halogen bulb. The manual makes it sound simple - just remove the rear cover and turn the bulb holder counter-clockwise. Okay, I wear an XL glove size, but at 5-09 and 190 lbs I'm not that far off of an average size guy. It was painful to force my hand into the small clearance to crank the bulb out. The H7 halogen bulbs were toast. After a trip to the local auto parts store, trying to engage the new bulb into the mount was a task I don't want to repeat.
Anyway, I succeeded. Rant over, job done. I wish the engineers that design this stuff were guys that actually worked on things instead of guys (and gals) that had an aptitude for math and got a mechanical engineering degree. I'm sure original assembly involved putting this together on a bench then screwing the entire assembly to the rolling chassis.:mad:
