Does anyone know if the 2017 F3 Daytona comes with both the cowl and passenger seat
Printable View
Yes, it does. Very nice. It actually limits the power output with the seat on. More power with just the cowl.
The Daytona is very flighty with 2 up. I can take a corner just a little above normal speed with my 90 lb grandson on the back and get wheel raise without cranking the throttle much at all.
The way I figured it out was that I was ryding one up with the seat on (no cowl) and I noticed that the byke wasn't a peppy as when I first got it. I pulled the seat and got to looking and there is a large spring loaded disk that the seat sits against and depresses it. When you put the cowl on there is a void where the disk is. I'll take some pictures if anyone is interested. I think it's a liability factor for them and that the Daytona is primarily a one up machine that you can carry someone for a while. Just don't challenge the twisties 2 up.
They also did a sensor on the seat of the RT for a passenger, too.
Interesting twist on the passenger sensor and handling of the machine...a bit disappointing..:banghead:
Has anybody asked Lamont about this question of power output changing for the presence or absence of a passenger? :dontknow:
I believe the switch is present on all F3 series spyders. On mine I know it's used for suspension and stability control changes when a passenger is detected... I thought the only difference with the Daytona is a "sport" mode that could be activated by the rider ??
im a bit skeptical since the BRP website lists the same HP and Torque values for the Daytona 115HP, 96ftlb torque. That would mean the only way to enter a "Sport Mode" would be via programming changes to the traction control system and vehicle stability system.
If the Daytona was capable of developing more HP and /or more torque at the tire wouldn't they list that in the vehicle specs ? As the Spyder website says about the "Sport mode..." It's our most permissive stability system setting yet"
This is the Daytonas cowl. I have circled the two areas in question. The bottom circle disk is spring loaded. When you put the seat on it, it will depress it notifying the computer that a the passenger seat is installed. The upper circle shows the depression that does not depress the disk on the bottom. Maybe someone can find out more about it. I believe that with the cowl,the Daytona is the only one this applies to.
Take the seat off, no cowl, ride. Press the switch, ride. You feel the difference! Joe
All F3s have the seat sensor. I understood it altered both the stability/traction control and the brake bias to account for the extra weight of a passenger.
I'm sure I've read somwhere what weight it requires to activate it. Just fitting the passenger seat won't activate it, you would need a passenger on it.
Of course it may also disable the Daytona's sport mode when active.
My switch doesn't activate unless a rider is present. I can actually press down on the passenger seat and hear it "click". I guess that means the Daytona doesn't actually have 3 modes ( normal, passenger, sport) . Question: How do you enter the "Sport" mode ? Is it controlled through the electronics mode switches on the left grip ? Or is the cowl/seat swap the only activation method.... Very curious !
Interesting, the Daytona rear seat or pillion rider switch must be different then. Can't get at mine to compare as it's tucked up under it's outdoor cover as the weather is a bit wintery here.
Found this in the WSM:
PRS Pillion rider switch
Signals the VCM when the PRS switch is depressed. the VCM applies changes to the control parameters, mainly to reduce maximum allowed lateral acceleration and yaw.
The PRS should definitely only be active when someone is sat on the seat, not all the time. It does rest on the switch but their is a fair bit of travel in it to activate it.
WSM pages attached:
